Question about Coaster Jessica King Bedroom Platform Bed 200711KE King Bed Coaster
How to ground light fixture
I need help trying to ground the light fixture so that it works. i would love detailed video or a DIY kind of video would be good
Do halogen light fixtures have to be grounded?
All light fixtures should be grounded IF they have a metal casing. If they are plastic caring there is no need for a ground. I doubt a halogen has a plastic case, they get much too hot
Oct 09, 2015 | Electrical Supplies
Tying into existing groundless knob and tube to run a couple fixtures and one outlet. Grounds?
Being as it is in the bathroom, there should be a cold-water metal pipe near. Attach a green conductor using an approved ground clamp. Run the wire to the outlet you want to ground. Attach to the box (if metal) then attach to the receptacle. If you can't get a ground installed as described, you could protect all the items (ceiling light and light over the sink) with the GFCI. All you need to do is feed the two items from the load side of the GFCI instead of the line side. This provides "people" protection as the GFCI function does not require a ground to detect the imbalance between the "hot" and the "neutral". This does not provide "equipment" protection.
Apr 23, 2015 | Electrical Supplies
Why is the light switch not working after i have wired up ceiling light
check to make sure you have all the white (neutral wires connected as well as the wire to the fixture. Make sure both wires from the fixture are connected to the wires in the light outlet box. White to white(maybe more than 1 in the light box) to the white (common) of the fixture an a different color (usually black or red) to the black from the fixture. Connect ground to ground wire or metal box. Turn the circuit breaker back on, if you turned it off, and turn on the switch. If this doesn't help it is time to get someone who can operate a multi-meter and understands electrical troubleshooting.
Jun 28, 2014 | Electrical Supplies
Flood lights in back yard not working
Which kind of flood lights? Long time lighting during whole night or security lighting sensitive to people walking across.
If it is for long time lighting, you should select the fixture lighting source as compact fluorescent, led or small wattage HID lamps, this kind of fixture you do not have priority requirement for instant on, the following fixture is just for reference.
http://www.bulbspro.com/vista-10040-35w-hps-wall-fixture-w-photoelectric-eye-bronze.html
For security purpose, you need the flood light right away reach full brightness, normally you take following fixture with halogen bulbs.
http://www.bulbspro.com/vista-10031-motion-sensor-twin-light-control-kit-white.html
Nov 10, 2013 | Dishwashers
Okay where do i find the ballast in relation to the glomar track lighting, I am an novice at this, sorry and thank you
Which kind of glomar track lighting, could you please give more detailing information, normally you can find the detailed information from the track head fixture.
Sep 05, 2013 | Home
Using 24 chauvet par 56 led and chauvet obey 40. when going to bank 5, 6 or even 11, some fixtures will remain on while some will flicker. 2 fixtures per channel on the console. DMX addess starting at 1...
Read about terminating the chain with a resistor 120 ohms. If your run has appreciable length, a termination MAY be necessary to avoid digital reflections that can corrupt the message between the control and the lights. Having separate power sources CAN subject the units to "ground bounce" that can also corrupt the digital control. You need to power all the units from a single source or conditioner if possible. Another solution might be to use one of the DMX radio links which would isolate the ground problem. Another fix you MIGHT try is to get some of the clamsheel ferrite devices that clamp around the wires. Put these around the digital cables, not the power cords:
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=ferrite+core&cp=8&bav=on.2,or.r_gc.r_pw.&wrapid=tljp1304006132890014&um=1&ie=UTF-8&cid=761843538070174409&sa=X&ei=-Y25TaXFGsjYiALh_8ky&sqi=2&ved=0CFEQ8wIwAw#
Apr 28, 2011 | Chauvet (4) Chauvet Led Par 56-24c 7...
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
How do I wire a single light to a on/off switch
Add a comment and say what wires you have in case following answer misses your mark.
As a general rule, there is one cable that comes from breaker box.
There is another cable that goes to light fixture.
Each cable has 1 Black, 1 White and 1 Bare ground.
So you have 2 Blacks, 2 Whites and 2 Grounds.
White wires twist together and are covered by wire nut.
Black wires each connect to a different brass-colored screw on light switch. In any order.
Bare ground wires connect to green screw.
If light fixture has wires, then black goes to black and white to white, and ground to ground.
If light fixture has screws, then black goes to brass screw, white to silver screw, and ground to green screw.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Jan 03, 2011 | Electrical Supplies
Coaster Jessica King Bedroom Platform Bed 200711KE King Bed Coaster Logo
Top Coaster Furniture Experts
Tom Chichester
tfelton3
ray gallant
Are you a Coaster Furniture Expert? Answer questions, earn points and help others
