Question about ATP 1995 - 1996 Chevrolet Lumina Van Auto Trans Detent Cable End Clip ATP
How do you change a harmonic balancer on a 1995 Chevrolet Lumina van?
How do i change the harmonic balancer on 97 lumina?
you may have to use a three fingerd pully
Feb 06, 2013 | 1997 Chevrolet Lumina
How do I remove the harmonic balancer on a 1992 Chevrolet Lumina APV. I have removed the bolt from the crankshaft and the Haynes book says to remove it by hand. It will not move.
You will need to get a puller. They can be bought at most autoparts stores, some will even rent them. Just be sure that you tell them it's for a harmonic balancer. Attach it to the balancer with the included bolts and tighten it up. When it gets tight give the tightening bolt a sharp rap with a hammer and tighten some more. Continue until the balancer comes off. Hope this helps.
Jul 23, 2011 | 1992 Chevrolet Lumina APV
My 1992 chev lumina apv van stalls everytime i put on the brakes at every red light it restarts after no codes are coming up what could it be?:
check to make sure the power brake booster is not leaking, do this by starting the van and just let it idle in park and push the brake pedal if the engine stalls or surges or you hear a sucking noise under the dash then replace the power brake booster if there is none of these systems then replace the idle control motor. GOOD LUCK
Mar 08, 2011 | 1992 Chevrolet Lumina APV
Changing spark plugs 95 chevy lumina van
you will have to take off the coil packs and move them out of the way. then go in from the top. its kinda tight but just move whatever else is in the way
Jan 09, 2009 | 1995 Chevrolet Lumina
Lumina van engine swap
i think you have to change the computer two
Sep 04, 2008 | 1995 Chevrolet Lumina
Lumina van 1995 won't start
IS THIS A 3.8 BUICK ENGINE? I HOPE HE HAS THE TOOL FOR LINING THE SENSOR UP PROPERLY. IT IS EASY TO DAMAGE THE SENSOR DURING THE PULLEY REPLACEMENT.
THE SENSOR CAN BE REPLACED WITHOUT THE TOOL BUT IT TAKES ALOT OF FIGITING ARROUND AND DOUBLE CHECKING THE AIR GAP WITH A FEELER GUAGE WHEN DOING IT.
Aug 12, 2008 | 1995 Chevrolet Lumina
Rear Brakes On Lumina Van
95 lumina mini van,,how to install rear brakes,,,how to replace the u spring???
Aug 12, 2008 | 1995 Chevrolet Lumina Apv
ATP 1995 - 1996 Chevrolet Lumina Van Auto Trans Detent Cable End Clip ATP Logo
255 people viewed this question
Top ATP Electronics - Others Experts
Are you an ATP Electronics - Other Expert? Answer questions, earn points and help others
