Question about Sanyo DS27910 27" TV
Tuning Sanyo VCR
Can anyone help me, I have a Sanyo VHR H791E video recorder, I need to tune in the TV channels. Please Help.
  • Portfan Apr 21, 2008
    I have a Sanyo VHR-5436 VCR without a remote. I need to set-up the channels. When I stop the tape the screen says [Set-up Channe] Enter. The enter key on the universal remote doesn't seem to do the job. Will this solution set-up the channels. The VCR is connected to a cable TV service.
Press both channel buttons simultaineously for 3 seconds it will automatically tune your programmes press ok when ok flashes on vcr screen display
Posted on Dec 28, 2007
  • Sanyo Master
  • 5,138 Answers
Go to vcr menu press autoprograming.
Posted on Dec 26, 2007
SOURCE:
How do i hookup a sanyo vhr h607 to my television
Unless the VCR has a digital tuner the only way to record off the TV will be to connect it by a scart socket and cable. However to record you would have to watch the TV show you are recording. An alternative is to get a set top box, which are fairly cheap and connect that to the VCR. Some VCR's have two scart sockets one for the TV and a spare one. You can connect the box via the spare one. When setting the recording you will have to select AV2. If the VCR has only one scart socket you might need a scart switching box.
Oct 17, 2014 | Sanyo VHR-H607 VHS VCR
My Samsung VCR has packed up. I want to replace it later with a DVD Recorder and in the meantime I have been given a Sanyo VHR-VK210A to use until we get our DVD Recorder. The Sanyo has only 2 sets of...
Hi Ken,
Initially, the video usually is the yellow, while red and white would be audio.
Your Sanyo VHR-VK210A would two (2) sets of these, one will be for INput (if you want to connect another DVD, a VCR or a tuner) while the other set would be the OUTput which will have to be connected to your TV.
Will post back if I can get my hands on a manual for you to download to help you with the remote.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 30, 2008 | Televison & Video
I have an old sanyo TV with only one av how can i tune VCR into a
You don't need too! All you need to do is get one of these boxes and you can connect all to that one scart, plus record the freeview to your vcr. They are not expensive, I got mine from Amazon.
Apr 04, 2010 | Sanyo VHR-H531 VCR
Need to retune Sanyo VCR VHR-610.
On the Sanyo VHR-610 you start the TV auto tune by holding down both the CHANNEL ( +, - ) buttons on the VCR simultaneously for more than 2 seconds.
The TV stations in your area will be automatically preset in order starting from programme position number "01"
When all available stations have been preset, the function will stop and the TV station preset to programme position number "01" will be tuned on your TV screen.
In other words after holding down the two buttons, leave it alone for awhile (takes some time) till it ends back at 01.
Cheers
Apr 07, 2009 | Sanyo Televison & Video
LG VCR GC480W can't tune in to tv
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Jan 27, 2009 | LG XBR446 DVD Recorder/VCR
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Mar 19, 2008 | Sanyo VHR-5431 VHS VCR
I need to tune a SANYO VCR VHR 220
I found a site that gave general instructions on tuning in the VCR with the TV and I managed to work it out.
Thankyou anyway.
Mar 14, 2008 | Televison & Video
Tuning in Akai Video
Please explain what you mean by "tuning in."  Are you referring to hooking up to your Television, or to a cable/satellite box?  Or can you not see video when you play a VCR.
Check your hookup cabling.  With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV.  Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Oct 30, 2007 | JVC BR-S622DXU VHS / S-VHS playback VCR
Sanyo DS27910 27" TV Logo
262 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
