Question about Globe Bantam Skateboard
Broken mini cruiser wheel - Globe Bantam Skateboard
Where is the steering wheel lock located?
If you have the original broken key try putting a mini drop of super glue on broken tip of key ( use a pin or needle to make mini drop) no wider then the width of key excess glue could make key stick in lock, reinstall key if all goes well after 2-3 minutes key will pullout broken piece with it when you remove it . Additionally lock mechanism is in the steering column Not easily accessible .
Apr 17, 2016 | 2001 Hyundai Sonata
I have a 2002 PT Cruiser that rides as though it has no suspension system at all, going over the smallest of bumps feels like I hit a giantic sink hole, what do you think the problem is and how do I f
The suspension system being that old probably needs some major work. Beside being a short wheel base does not help. The longer the wheel base the smoother the ride. I bought a new car a short time ago(cross-over) , did not like the ride. Bought a mini-van a year later. Much smoother ride and better gas millage.
Dec 31, 2014 | 2002 Chrysler PT Cruiser
Flywheel spins freely but engine does not turn over
not really possible unless you have a broken crank shaft at the rear main bearing or if automatic then the flex plate has broken off around the flywheel bolts . The torque converter will hold the flex plate in position and if manual then the pressure plate on the throw out bearing will maintain the flywheel in position. Unless you are saying that the motor spins freely but will not start which is different . If that is the case check that the cam shaft is turning(broken timing belt) and bent valves.
Jun 01, 2014 | 1998 Toyota Land Cruiser
2005 mini cooper has loud humming noise from rear when driving above 40 mph. Any suggestions on what this could be
I had a similar issue and it ended up being a broken wheel bearing. I even ended up having two, one was broken on my front passenger side, and one broken on my rear driver side. The part costs about $280.00, but could cost around $400.00 with service repair. The noise of a broken wheel bearing can sound like a humming, and over time it becomes louder. The car can be driven with a broken wheel bearing, but doing so can eventually lead to other wheel/tire maintenance. MINI's endure this commonly due to their low profile to the ground. Here is a forum on further issues experienced, including the bearing, and efforts towards recalls. http://newmini.wordpress.com/2009/02/17/mini-cooper-power-steering-failure/#comment-884
Oct 10, 2010 | 2005 Mini Cooper
The horn honks every time the steering wheel turns. Where is the horn fuse for a 09 pt cruiser?
if the horn is going off when you turn the steering wheel that means there is a loose wire in there. or the clock spring is broken, what i would do is have someone who knows how to deal with air bags take it off and check the wires it shoule only take 30 min to check, and if to much to repair they can disconnect it right there.
Nov 18, 2009 | 2009 Chrysler PT Cruiser
Steering wheel on a 2005 PT Cruiser
sounds like your clock spring to your air bag is damged any junk yard should have these parts its simple just got to know what your doing
Jun 18, 2008 | 2005 Chrysler PT Cruiser
Software
Hi…I have the 3-D Cruiser Software. I’ve actually just put the whole game (original box) up on ebay – username – babadee. I’ve gotten a bunch of emails from people needing just the cd so I’m making copies and offering them for $8.99 plus $3.00 shipping/handling. If you’re interested or know of anyone else, I can be reached at jncarling@aol.com…thank you377428
May 29, 2008 | KB Gear Little Tikes 3D Cruiser (1727)...
Globe Bantam Skateboard Logo
574 people viewed this question
Top Globe Sport & Outdoor - Others Experts
Are you a Globe Sport and Outdoor - Other Expert? Answer questions, earn points and help others
