With the Lanier LCR-5, can I put a tape in one side and have it record onto a blank tape on the other side?
  • 205 Answers
SOURCE: how do i put a tape recording onto the pc?
dg9dotorg is correct about the memory card. The memory card and USB cable can be used to transfer still images only. To transfer the video you need a DV cable (also called a Firewire cable).
If your PC is relatively new it most likely has a firewire port. If it does not then you'll need to purchase a firewire card.
You will also need software to capture the video. I use Scenalyzer. You can download a demo version of this software at no charge. The link is http://www.scenalyzer.com/
The demo version is fully functional, but it will put a watermark on your video.
Good luck.
Posted on Dec 09, 2007
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
SOURCE: Is there any way to record a video onto the sd card instead of tape?
You can't. SD card is only to take images in this camera.
Posted on Dec 23, 2008
javer821
  • 207 Answers
SOURCE: Lanier tape dictation machine
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
are the Best
Posted on Dec 12, 2009
willell
  • 67 Answers
SOURCE: how do i record on the vcr
do you hve anything going into either the cable in or the rca (red white yellow)?
if you do then make sure the correct input is selected
Posted on Jan 19, 2010
How do you record on a Lanier p-164
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Jun 06, 2014 | Audio Players & Recorders
Tape recorder will no longer play or record
Tape players need maintenance often. You have to replace the belt, clean the rubber roller with Rubber Renue, put grease on the odd spot and clean the head by rubbing clean white paper on it. Any electrical contacts like a volume switch etc need a contact spray to remove oxides etc. This should be done every 5 years or even more often if used more often.
Nov 07, 2013 | Lanier Audio Players & Recorders
Lanier Advocate V System - Automatic Changeover
Hello make sure you full rewind the erase tape on the deck 2 you will see the green light Ready, that’s when you can start the Deck 1to record when is almost to the end Deck 2 will start
Jan 22, 2010 | Audio Players & Recorders
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it...
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Nov 13, 2009 | Lanier VW-160T
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Tape to tape recording
Just put the tape to be copied in side A while the other the blank tape in side B. Press the play in side A . Then in side B simultaneously press the "Play " and the "Record". Then it will starting to record it will automatically stop.
Good luck:
Dont forget to rate:
Jul 01, 2009 | Panasonic SC-AK18 CD Shelf System
Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
Recording from vhs to dvd
Jan 20, 2008 | Televison & Video
Need Help recording television onto vhs
Probably cabled wrong.
Make sure the VCR is getting a signal to record.
Put in a movie and get the TV set up to watch it.
Now put in your blank tape and switch the VCR to what you want to record and make sure you can see it on the TV.
Dec 17, 2007 | Televison & Video
Sony DCR-HC38 not recording or playing
try to clean the video head...just forward a blank new tape 5 times...until the head is being cleaning...dont use a video head cleaner...just think using a sand paper to the head....it damaging the head
Aug 08, 2007 | Sony DCR-HC38 Mini DV Digital Camcorder
29 people viewed this question
k24674
jasbo
jasbo
