Question about Transmission & Drivetrain for Isuzu MU-7
How much oil in transmition
Where is drain plug
  • 48 Answers
The transmission holds 6 litres of transmission fluid. There is no drain plug unless it was added by someone else. You will need to remove the pan to remove the fluid. I suggest loosening one side more than the other to allow the fluid to exit on one side into a catch basin.
Posted on May 15, 2014
    Problem Solver:
  • 19 Answers
Note: when you drop the oil from the oil pan to check the oil filter.
I personally would replace it.
Also remember that when you fill the transition again that you wont have changed "ALL" the oil in the transition! There will still be quite a bit of the old oil still in the toque converter (fluid coupling) look for a drain plug in the toque converter, note that not many manufactures put drain plugs in toque converters.
Posted on May 17, 2014
Does a 2003 kia sedona have a drain plug for the transmition and where is it located, how much tranny fliud will it drain and how much tranny fluid will there be left in the tranny
If it's auto,the pan has to be remove leaving oil in the cover or, if it's manual drain plug is at the bottom of the box,no oil will be left,filler plug is half way up the g/box.
Nov 23, 2016 | 2003 Kia Sedona
How to drain transmition oil kia sedona 2002l
If it's an auto box, it cannot be drained without removing the pan from the bottom of the box or, much simpler, a clean polythene type tube, with a syringe, inserted into the gearbox filler tube, and draw some of the excess fluid out. If a manual box, there will be a level plug on the side of the box
Oct 06, 2012 | 2002 Kia Sedona
Location of drain plug of transmition
the oil drain plug transmission is below the top of the transmission to be more specific transmission is below
Apr 11, 2012 | 2003 Pontiac Montana
Lookig to change tranny fluid on 71 t350. there is two drain plugs. does this mean there is two different oils for the clutch and the gears? if so where is the fill for the gearbox and how much does that...
hi, the transmition/ or gearbox as is more commonly known has but 1 drain plug. this will be located in the middle of the crankcase lower,undo the plug and alowe the oil to drain away into a container, the gearbox and clutch use the same oil as it is all 1 unit, the crankshaft, cylinders aand bearings however are all lubricated by the 2 stroke oil which i am sure you know,
when refilling the gearbox with the correct grade of oil, you will pour it carefully through the small filler in the clutch case close to the front footrest, also in the side of the case slightly below the filler you will see a 10mm screwhead bolt, you will need to remove this as it is the level screw, pour oil slowly into the filler untill the oil starts to come out of the level hole, allow some time for the oil to stop coming out of the hole, when it has finnished dripping, then replace the level screw and the job is complete.
THE MACHINE MUST BE ON THE CENTRE STAND TO COMPLETE THIS TASK.
Paul
Feb 02, 2011 | 1971 Suzuki T 350
I want to know how can I change the engne oil
loosen the drain plug under the engine, if there is a oil filter remove it also.Change with a new oil filter and fill the oil approx. 3.2 liters.use your sight glass as ref.
May 27, 2010 | 2002 Cannondale X 440 S
Transmition oil change fill plug
most transmissions don't have drain plugs any more. Have to drop oil pan to drain fluid.
Some don't have dip sticks either.
Dec 26, 2009 | 2006 Ford Explorer
How do I change the transmition fluid in a 2008 toyota tacoma V6
there may be a drain plug on the gear box sump or you may need to take the gear box sump off to drain the oil out,,,thats a bit messey,,,
dont get any dirt in you gear box
Oct 30, 2009 | 2008 Toyota Tacoma
How to change gear oil for manual transmition
there is a drain plug on the very bottom should be a 24mm and a matching fill plug on the front side of trans about halfway up. fill trans untill fluid is even with fill hole
Jun 21, 2009 | 1991 Toyota Celica
Gear Box oil change How do i do it??
Trans fluid and primary fluid are the same oil , The drain plug is under the laft side primary cover. 1 qt of oil goes in the inspection cover on the top side of the primary cover. The oil drain is a hose under the left side by the frame rail. Look for a oil line with a plug. fill with approx 3 qts through the oil tank. Make sure you get the bike up to operating temp before dropping the fluid.
Feb 22, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Transmission & Drivetrain for Isuzu MU-7 Logo
64 people viewed this question
Top Isuzu Vehicle Parts & Accessories Experts
Randy Ohler
George Agios
George Agios
SriPhi
Are you an Isuzu Vehicle Part and Accessory Expert? Answer questions, earn points and help others
