Question about Kenmore 64902 Electric Dryer
I have a kenmore dryer purcased in 1986 model 11087673100 that runs but does not heat. can I get a thermostat for this dryer
SOURCE: Heating element
It was very easy to do on my dryer. Kenmore 80. Removed 8-10 screws. Ordered a new element on Thursday afternoon from
http://www.pcappliancerepair.com/index.html, had new one Thursday morning at 9:00 am. Paid for shipping on 3-7 days got it less than 24 hours. Plus paid $10 less than Kenmore site.
Posted on Mar 06, 2008
  • 131 Answers
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
Posted on Mar 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer model #86870100 runs but no heat
this kit mounts on the heater element chamber. The small one will be open. The big one failed also because it is rated to shut down @250°F. The little guy is rated at 300°F. NOTE: when this limit fails it is a sure sign of a blockage of lint somewhere.8e8a912.jpg
Posted on Dec 15, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Posted on Feb 05, 2009
marka19
  • 1430 Answers
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Posted on Mar 28, 2010
Kenmore dryer he4 elite dryer not heating model #95862402
using multi-meter need to check the heating element and the thermostats for continuity. you are getting a full 240 volts at the outlet right? if only 120 then u will be able to run the appliance but not the heating cycle.
Sep 25, 2014 | Kenmore Elite HE4 Electric Dryer
How to replace belt on kenmore model 11087673100 Dryer?
there should be a belt diagram on one of the inside panels to the unit
Best regards
Ck
Aug 18, 2011 | Summit Commercial Summit CEDC392PQ ELEC...
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
Kenmore Model 110.96585200 No heat!
You probably have a bad thermal cut-off . This is the small thermostat , located at the top of the element housing . This " thermostat " should read infinate resistance ( no resistance ) . You can put the 2 wires togather , and see if heat comes on . pt # 3399848 . Both thermostats , should read 0 resistance . They are normally closed . The thermal cut-off , will not reset itself , if open . This is a safety t-stat , for when dryer gets too hot , and will have to be replaced .
Nov 11, 2009 | Kenmore Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Kenmore Dryer 60982 Runs but No Heat
you can check them all with an ohms meter but i think it is the thermal fuse at the top of the heater box that is bad-mike
Jun 04, 2009 | Kenmore Dryers
Electric dryer heat coil off mid cycle
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Runs but no heat
most common cause of no heat is a blown thermal cutout, over temperature cuthout, thermal fuse (any of a dozen or more names for the same article
examine the exhaust vent ducting inside the dryer for screw on device that looks like this d7573a1.jpg or this 0874a9a.jpg, with wires on the terminals. they are not resettable but they are cheap. despite the large number of dryer models there are only a few cutouts, used in multiple dryers, the local parts guy will be able to match it easily.
test with battery annd bulb, or ohmmeter
conducts-good, no conduct- replace
if you havent disposed of them already, retain the heater and thermostat, they are probably good, and will make spares if the parts guy wont buy back the replacements
Aug 29, 2008 | Kenmore 63942 Dryer
Kenmore 64902 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
