Question about Samsung HW-D450 Sound Bar
Xfinity remote control codes
What code allows the x1 remote to control volume for the Samsung HW-D450 soundbar?
snakehead
  • 1074 Answers
SOURCE: Samsung Remote Issues
if the tv is a new tv along with remote take it back to the supplier it should still be on warrant.good luck
Posted on Apr 18, 2007
SOURCE: Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
Posted on Jun 02, 2008
crayzeetrayn
  • 837 Answers
SOURCE: Need remote control code
0867 should do it
Posted on Jan 14, 2009
SOURCE: verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Posted on Mar 28, 2010
nainamainaka
  • 380 Answers
SOURCE: virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Posted on Nov 18, 2011
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
Apr 26, 2017 | Televison & Video
Can I program a GE 24116-V2 universal remote control to operate a Xfinity X1 Cable box ?
This remote control have no setup codes to Xfinity. If you wish to get more details visit the site linked here. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://homenol.blogspot.com/ Setup procedure and set up codes for many popular brand remote controls are given.
Feb 08, 2017 | GE Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Hooked up HW-D450 sound bar to Samsung UN40D6000SF TV with low output from sub woofer
Have you adjusted the subwoofer level? there should be buttons on the remote to adjust this level. Also, make sure you are not in a 'night' surround mode - this drops subwoofer levels a lot
Apr 08, 2015 | Samsung HW-D450 Sound Bar
How do I control my HW-E350 soundbar using a Comcast Xfinity remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Jan 01, 2015 | Televison & Video
Need to program my Samsung TV remote BN59-00854A to control the volume on my Samsung Soundbar HW-FM45C. Any ideas?
You should set it up with its set-up codes. You might have to check diffierent codes said to Samsung brand audio devices, until you get control the volume to your sound bar. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Nov 23, 2014 | Televison & Video
Samsung HW-D450 dont turn off power whit harmoney 1100 power off
1= Reset the code again. go www. fitness.manualsonline.com or www.remotecodelist.com
2= Retight the springs contact, with pliers very well for a good contact battery.
3= Clean the contacts with special spray contact.
4= Open the remote for to clean the keypads, with special spray contacts.
5=Otherwise, you must go to the repair shop,or to buy a new ones.
God bless you
May 16, 2012 | Logitech Harmony 1100 LCD Touchscreen...
Replacement remote for Samsung HW-D450
Hello
If you want to buy its original remote control, you have to contact the nearest service center for Samsung at your town. Provide them the exact model number of your TV set.
If you want to buy a universal remote control, select an RCA RCR -------- model, which have setup code for Samsung. You can see the setup code list alongwith the universal remote control.
Feb 14, 2012 | Samsung Cell Phones
Samsung HW-D450 Sound Bar Logo
70 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
