Question about GE Dishwashers
How do I replace lower wash arm base on ge dishwasher model gsd4000n10bb
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
SOURCE: Can't remove lower spray arm
the nut screws off counter clock wise.
Posted on Mar 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
The quality/quantity of responses you get here on FixYa can greatly vary for WHEN you place your question.
There are a handfull of "experts" who use fixya that simply have a generic cut and paste answer for every question asked on FixYa.
"Final Answer" is one.
Many have little to no english skills, and resort to cutting and pasting the same answer to every question.
I apologize for their ignorance and im sure your post will soon be answered by knowledgeable QUALIFIED personnel.
Real answers are not automated here - I assure you. Give it a little time for our experts in the US to wake up and get coffee into their system.
We are not employed by FixYa - sitting in a little cubicle waiting to answer questions. Most of FixYa experts do this in their spare time between real service calls.
Be assured that if you are not satisfied - it is easy to request a refund. Please email Lauren@FixYa.com if in the next day or so you have not gotten a fix to your problem.
Now that's out of my system I can try to help troubleshoot your problem.
Bosch dishwashers use a water system called FLOW CONTROL... which utilizes a valving system to control which arm gets water during the cycles.
Most washers see water at both arms all the time. Yours is controled with a PLC and uses information gathered from onboard sensors to tell the valves to open or close.
Your Lower sprayarm valve is faulty, or the controller board is bad.
Since we do not know your mechanical/troubleshooting skillset - all we can do is offer advice and try and help you if you feel this is a problem you would rather attempt to tackle yourself.
I have searched BOSCH website and could not find your model washer in their documentation. Please double check that it is SHV55M03GB/40 that you posted.
Posted on Mar 20, 2009
  • 3 Answers
SOURCE: Cannot remove lower spray arm ge dishwasher GSD5911
Some spray arms out there are reverse threaded, however the one that you are dealing with should be regular threads. Should be an opening at the very bottom of the spray arm where you can stick a screwdriver through and use both hands(one on each end of screwdriver) and carefully loosen it. Make sure you get the new one on as tight as you can by hand, then check to make sure its tight by using the screwdriver again. With the screwdriver through the hole, and one hand on each end of it, just apply pressure clockwise, but you do not have to force it. Hand tight plus an ever so slight turn with the screwdriver should do it. Don't forget that anytime you are replacing the spray arm, you must always check once the new one is in place that you do not have a leak underneath the dishwasher. Also remove all water before you start replacing the spray arm to prevent water from leaking once you break the seal when loosening the spray arm.
Posted on Apr 04, 2009
  • 2501 Answers
SOURCE: lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Posted on Dec 14, 2009
Testimonial: "Thanks for a speedy and v helpful reply. Sounded obvious, but I hadn't checked the water inlet(which was calcified)just the jets on the arm itself! "
How do i change the lower spray arm of a GE Monogram ZBD6880K10SS?
there is a fine filter hub nut that holds the base of the arm in place the two must be disconnected from one another to be able to install a new arm.
Aug 15, 2015 | GE Dishwashers
How do I remove lower spray arm
Pull out the lower wash rack. Using a flat-bladed screwdriver, CAREFULLY pry the 2 tabs at the bottom of the washarm so it can move up and over the "hold-down plate" Be careful! Those tabs have a tendency to break off, especially the older the dishwasher is. You may be forced to buy a new wash arm.
Feb 25, 2015 | GE Dishwashers
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
How do I remove the bottom arm to unclog it?
Based on my dishwasher which is a similar model, unscrew the cap on the support arm. Then lift off the lower wash arm. (Turn counterclockwise to loosen.)
There are several models of the KUDS02FRSS and the parts diagrams and manuals are available from http://www.managemylife.com/mmh/owner_manuals/search?query=KitchenAid+KUDS02FRSS .
I hope this helps.
(we recently had to take off the the lower wash arm to replace a seal; by the time the part arrived, we forget how tight the cap was on originally. Pay close attention to the wash arm ease of rotation when you disassemble it. We overtightened it and the arm refused to spin until we corrected the mistake.)
Feb 26, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
The water is not getting to the top wands
you need to replace the water conduit that runs from the base pump area up the back wall to the center and top wash arms,the "water horn" that feeds the center arm when the drawer is pushed in gets leak by and this in turn lowers water pressure to the center and top wash arms,replace the whole conduit as its not that expensive,and while doing this clean out and blockages from food in the spray arm holes too
Feb 09, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Heavy film left on dishes. when rinse only frunction is used in empty dishwasher with no soap, the door and interior are still not clean. soap scum remains.
Hi and welcome to FixYa, I am Kelly
Most of the time when you start having dirty dishes post wash there is either an internal blocked screen under the lower wash arm tower or a problem with the drain. The drain problem shows up mostly inside the Air-Gap cap or at the garbage disposal / sink port connection. Pull the cap / cover off of the Air-Gap and then NOTE the installed position of the inner cap. Unscrew the cap nut and lift the cap off of the Air-Gap assembly. Food particles block the drain inside the cap. You should see a blockage as soon as you lift the cap or the particulate falls away as you lift the cap. Look into the Air-Gap with a flash light and clear any debris. Re-install all Air-Gap parts after cleaning. Make sure to pull the hose off of the garbage disposal port and clean the port.
Add water via cycle fill and then test the drain cycle. The dishwasher should be empty in less than 90 seconds. After 90 seconds interrupt the drain cycle. There should NOT be standing water in the dishwasher sump. If you have standing water in the sump after 90 seconds you will have to remove the lower wash arm and tower to clean the screen or drain holes in the tower. (depending on modeL) Another thing to pay attention to is exactly HOW the lower wash arm is installed on the tower. Some of the 2 part lower wash arms can be a nightmare to re-assemble.
When in doubt take pictures first.... (Lesson learned the hard way too many times when a 30 minute job goes in to the 2nd hour on my time!) Just make sure you do NOT remove any motor pump mounting hardware where it mates to the tub base. Even loosening a motor pump bolt or screw can cause a leak after your done.
While the lower wash arm is removed make sure that you inspect and clean the inside of the wash arm. Often food particles can block the water spray holes in the wash arm.
IF you have a direct / no Air-Gap sink connection then pull off the hose at the sink connection and clear the connection hole of any debris.
One last thing to look for is clogged upper spray arm water holes. Just inspect for signs of blockage. Only remove it if you note food particulate in the holes or under the wash tower base.
I am speaking from many many years of in home appliance repair experience. The steps above should stop the dirty post wash dishes. If you still have the same issues please respond with an EXACT Make and Model Number so I can look at the mechanisms of your dishwasher before responding again.
Thanks for choosing FixYa,
Kelly
Jan 17, 2011 | General Electric Spacemaker® GSM1800N...
Dishwasher not washing dishes, water not spraying around machine
Could be the flood float is stuck. Try banging it with a spoon. This worked for me, believe it or not! Here is a link to a video showing this for GE dishwashers:
http://www.geappliances.com/videos/dishwashers.htm?sURL=http://geindustrial.edgeboss.net/flash/geindustrial/appliances/dishwashers/mx_support/wont_fill_water/flood_float_for_customers.flv
Nov 09, 2009 | Dishwashers
I have a GE nautilus dishwasher Model GSD4000N10BB that is white and I would like to replace the white door with a black one. Is this possible and how much will a new door cost?
hi, I believe it is possible to change the colors. I looked up your model # and found only black listed. I then changed the 2 end letters to "WW" and found the doors are white. If you would call C.E. Sunberg @ 1-800-621-9190, they will be able to confirm that this is possible.
I hope this helps you. Please let me know.
Thanks
Vic
Jul 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
14 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
