Question about Coleman Powermate Powermate 5000W Generator
Need an owner's manual for a rodac LT950 generator
I need a parts list and drawings because a small spring has fallen off and genny won't start
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: My powermate portable generator runs but no AC
Hi. Lets cut to the chase here... Check for 5 - 7 DC volts on the brush block wires with the unit running. No voltage = bad VR Voltage = possible bad brush block or... that you may need to flash the generator field. I know you asked for a service manual but I am telling you these simple steps will save lots of time money and grief.
If you disconnect ONE wire off the brush block you should be able to read resistance of the armature. If you can not read that resistance then the brush block is probably not contacting the slip ring. If you do read resistance across the brush block with one wire disconnected then it is time to try a field flashing.
The manual calls for applying 6 VDC to the brush block wires engine running to flash the generator field . Over my many years of working on generators I have found that you can use an electric drill plugged into the the power outlet and the output power switch ON. You then turn the drill as fast as you can by hand...(YOU MUST PULL THE DRILL TRIGGER at the same time.) It is a little work to do this but it works well. You must be careful though because once the field does flash the drill is going to run... i.e don't grip the drill chuck to tight or at least LET GO of the TRIGGER when it takes off! What ever you do avoid using a rag on the drill chuck while turning it.
Give all of the above a try first and if we really have to, I will dig out the manual and copy and paste text only :( pictures I will have to send you links for.
Thanks for choosing FixYa.
Kelly
Posted on Sep 06, 2010
My EB2200X generator won't generate electricity
Check output on diode pack on the back of genny maybe stuck or brushes need replacing.
Oct 15, 2014 | Honda Em1600x, 1800x, 2200x, Eb2200x...
Hi , I have a 2500 watts honda generator , it's starts & sounds alright but when you plug a power tool and once you press the trigger of tool it shuts off right away ... What could be the problem ?
Wow, you must have one mighty bit power tool there. The Honda genny should accept it easily. You don't mention the current draw of that power tool - it should be under approx. 2200W to allow for start-up load. The other possibility is an excessively long power cord or even a short-circuit in the tool ...... or a problem with the genny itself! Try plugging in your wife's hair dryer to check it. Failing that you should get an electrician to check it all out.
Good luck.
Sep 01, 2014 | Electrical Supplies
Owners manual
High amperage draw on motor on startup
May 04, 2013 | Coleman Powermate Proforce 2500 Generator
Can I change a 10hp generator motor with an automatic throttle to a manual throttle?
Yes, you will be able to control the throttle. Look for a lever that pulls on the governor spring. On some generators, the governor spring attaches to an arm with adjustment screw and locknut or metal tab that bends into position. All that you need do is to pull on the governor spring to increase rpm. The governor spring pulls on the governor arm that is attached to the fly weight governor inside the engine. The fly weight is turned by the cam gear in most cases and the force that it produces is constantly trying to close the throttle. The governor spring provides the counter force to open the throttle. Without the governor, the engine can over rev. Good luck with your project.
Nov 18, 2011 | Briggs & Stratton Electrical Supplies
I have a Toro Self Propelled lawn mower. The pull cord broke when I tried starting it. As I went to fix the cord I noticed that the spring to pull the cord broke. Is there any way to fix the spring...
You need to obtain the model number off the engine and go to a website that has small engine parts, and likely schematics. Enter the model number and find your engine and when you get a list of illustrated parts drawing select the one for the starter or recoil strarter or some such listing. This will give you an exploded view illustrated parts drawing and you need to find the broken parts. Take the number that identifies it on the drawing and look to the associated table. This will give you a part number and allow you to order it.
I hope this helps.
Jul 22, 2011 | Toro Lawn Mower With Toro Power Tools
2002 Yamaha TT-R 250 why will my kick start not go all the way down?
Hi, Summitt60 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Won start Kick start won even go down it like it stuck Banshee Repairs and...
spring kick start gear problem
Yamaha TTR250L Service Manual
OEM parts for Yamaha
Yamaha TTR250M Owner Manual
May 09, 2010 | 2002 Yamaha TT-R 250
Kipor 6700t - The battery keeps dying on my genny. I changed it today but now it turns over but doesnt kick in. Any ideas? Em
Ff you do not have a draw an the battery.
It is the battery.
Unless you cycle your generator every few weeks this small battery will drop below 12 volts and start destroying it self.
SOLUTION:
Our best fix was to add a 5 watt solar panel and now the battery stays above 12 volts and has extended its service life.
Hope this tip helps.
R/
David
Mar 11, 2010 | Electrical Supplies
Governor problem on 9 hp vanguard engine
Go online to Generac and they have parts list and owners manuals online. They will ship you parts.
Jun 25, 2009 | Generac 5724 GP Series GP3250 Portable Gas...
Nedd owners manual, parts list and warranty info.
you have got a china copy, hard to get bits for.
whats the prob u got with yours
Jan 16, 2009 | Sunpentown 2,800 Watt 6.5HP Power...
Valve spring broke
Not sure but I think someone told me it is a knock off of the Honda? If so maybe try comparing? Ck size, Spring tension & etc?
I know not much help but that's where I'd start. Been told by a local small eng shop there aren't internal parts available for the Sumec engines.
Mike
Dec 09, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Coleman Powermate Powermate 5000W Generator Logo
64 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
