Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
The ratio of a to b is 6:2. If a + b= 112, what is the value of a?
  • The Learning... Master
  • 3,961 Answers
A / b = 6 / 2 so 2a = 6b or a = 3b
a + b = 112 so 3b + b = 112 so 4b = 112 and b = 28, a = 84
Posted on May 15, 2014
What is the ratio of 1meter is to 40 millimeter?
1 meter is 1000 millimeters, so 1 meter is 25 times 40 millimeters. The ratio is 25:1.
Sep 30, 2014 | Garden
What does the check engine code 0173 mean for the 1999 Mazda Millenia S?
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the MIL (2 trip detection logic).
Read more: http://engine-codes.com/p0173_mazda.html#ixzz3C76zKyGq
Sep 01, 2014 | Cars & Trucks
What is the loan to value ratio?
The loan to value ratio is thesize of the loan against the value of the property. A good example from Wikipedia is, "a mortgage loan in which the purchaser has made a downpayment of 20% has a loan to value ratio of 80%"
Aug 08, 2013 | Finance
Code 0171
Here is the definition.
Causes could be a faulty O2 sensor or a fuel problem.
P0171 CHRYSLER Description With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
Read more: http://engine-codes.com/p0171_chrysler.html#ixzz24c6wxqAd
Aug 25, 2012 | Chrysler Town & Country Cars & Trucks
What is the pi button
Pi is a mathematical constant whose value is the ratio of any Euclidean plane circle's circumference to its diameter; this is the same value as the ratio of a circle's area to the square of its radius. It is approximately equal to 3.14159265 in the usual decimal notation.
Mar 05, 2011 | Casio FX82MS Scientific Calculator
P0734
Description of fault code P0734:
This code is set if the value of input shaft speed is not equal to the value of the output shaft, when multiplied by the 4th gear ratio, while the transaxle is engaged in 4th gear. This malfunction is mainly caused by mechanical troubles such as control valve sticking or solenoid valve malfuctioning rather than an electrical issue.
From experience (sorry) you will end up replacing the transmission. This code usually indicates an internal mechanical failure.
Dec 28, 2010 | 2003 Hyundai Accent
The ratio of a to b is 2 to 5 and the ratio of b to c is 3 to 4, what is the ratio of a to c
To solve this, you need to multiply the ratios together.
(2/5)*(3/4) = A/C
So (2*3)/(5*4) = A/C
6/20 = A/C
You can reduce that be dividing both sides by 2
3/10 = A/C
Here is an example:
Let X = 3
The problem states that A/B = 2/5
So let A = 2X & B = 5X
A = 2*(3) = 6
B = 5*(3) = 15
Now check the ratio: 6/15 = 2/5. The same as what was given.
Now lets look at the ratio for B/C. The given ratio for B/C was 3/4
Using the value of B that we just solved we get:
B = 15
C = (4/3)*15 = 20
Check the ratio.
15/20 = 3/4
Now we have the values for each of the variables
A = 6
B = 15
C = 20
The ratio of A/C is 6/20
6/20 can be reduced to 3/10 be dividing both numbers by 2
Aug 22, 2010 | The Learning Company Achieve! Math &...
What is a STFT B1(%) -1.56. WHAT DOES THAT MEAN?
Here is some general information to get you started...
(I am quoting directly from several PDF sources, Googled).
STFT B1 = Short Term Fuel Trim Bank 1. This is the fuel correction percentage being used by the closed loop fuel strategy for Bank 1 (if a V style engine or for all cylinders if an inline engine). If the fuel system is in open loop, this number will be reported as 0%
Fuel trim refers to the feedback compensation value compared against the basic injection time. Fuel trim includes short–term fuel trim and long–term fuel trim.
Short–term fuel trim is the short–term fuel compensation used to maintain the air–fuel ratio at its ideal theoretical value. The signal from the heated oxygen sensor indicates whether the air–fuel ratio is RICH or LEAN compared to the ideal theoretical value, triggering a reduction in fuel volume if the air–fuel ratio is rich, and an increase in fuel volume if it is lean.
Long–term fuel trim is overall fuel compensation carried out long–term to compensate for continual deviation of the short–term fuel trim form the central value due to individual engine differences, wear over time and changes in the usage environment.
If both the short–term fuel trim and long–term fuel trim are LEAN or RICH beyond a certain value, it is detected as a malfunction and the check engine warning (CHK ENG) lights up.
If the total of the short–term fuel trim value and long–term fuel trim value is within ± 25 %, the system is functioning normally.
Apr 07, 2010 | 1998 Jeep Grand Cherokee
Wrong trig ratio
Your calculator is set in radians. Press mode key. Arrow down to 3rd line. Highlight degree and press enter. Your calculator is now in degrees, not radians. To get out of the mode screen and back to home screen, press 2nd and then mode.
Aug 05, 2009 | Texas Instruments TI-84 Plus Calculator
CPU RATIO?
Of course is has to do, almost everything has to do with overclocking, but what is that you need to know really? ... and personally I strongly recommend NOT TO OVERCLOCK.
Mar 09, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
95 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
