Question about Garden
Torque problem jcb 3c mk 3 will reverse but will not drive foreward
5 Suggested Answers
  • 6 Answers
SOURCE: makes a load noise and will not work in reverse,
be more desciptive its either your tranismistion or axel shaft gears
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: I would to know the cylinderhead torque for a 3c 2.2 diesel
1st 48ft-lbf
2nd turn 90 degrees
3rd turn 90 degrees
Posted on Sep 10, 2009
Testimonial: "Hi, that was very helpful, I appreciate it very much. Thank you. Even thou I didn't get the sequence and stages of the torque"
ineedabin50249
  • 755 Answers
SOURCE: jcb 532-120 1998 will only drive forward in 1st and 3rd gear but will drive in reverse gear in all speeds
I used to work on one of these , I think these are electronic shift modules , may be a dirty plug on the trans , may have the linkage off ,I forget ,
Posted on Sep 15, 2014
daytoncomput
  • 1511 Answers
SOURCE: JCB 214 series 3 will not move in forward or
The problem is serious and needs a factory trained technician to trace the problem with test equipment that you do not have.
Posted on Jan 05, 2015
MY GOLF4 MISFARE AFTER DRIVING 30KM AND IF I SWITCH OFF FOR SOME TIME THEN IT STOPS
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master.
It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, codes, diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
Mar 22, 2018 | Cars & Trucks
My 3350 has 270 hrs and starting to bog down after running 3 to 4 hrs. What are the possible problems.
service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
Feb 26, 2018 | Cars & Trucks
2002 chevy trail blazer i6 2wheel drive. alternater works sometimes
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
Feb 25, 2018 | Cars & Trucks
1995 nissan altima stops turning over. It will start and drive but once you turn the car off it will not start back up.
Feb 25, 2018 | Nissan Cars & Trucks
Gear box problem landrover series 2 discovery auto not selecting gears
at the bottom of the selector rod in the gearbox is a snall shaped cam which operates two switches one for foreward and one for reverse its possible that this has broke or its a computer malfunction also the front clutch has failed or low on oil maybe even the drive plate for the torque converter has broken in the middle but this would be noisy i would expect but not always
May 19, 2012 | Land Rover Discovery Cars & Trucks
I WAS PLOWING SNOW TODAY WITH MY 1990 F250 7.3 DIESEL AND THE TRANSMISSION QUIT WONT MOVE FOREWARD OR REVERSE WILL MOVE SOME AT 4000 RPM. LOTS OF FLUID NO BURNT SMELL IN THE FLUID
Only thing reverse and forward have in common are torque converter splines and pump. Is the fluid level high? This could mean pump and or converter has failed.
Jan 22, 2011 | 1990 Ford F250
How do I fit a fan belt on a JCB Mk 11?
Undo the bolts on the front crank pulley and the drive shaft should slide forwards on the spline to give enough space to get the new on in. Whilst doing it put a second one in place and tie wrap it out of the way so you can fit it easily next time
Dec 30, 2010 | Computers & Internet
My jcb will work fine in reverse but only sometimes in forward
is it a torque gear box if so your torque is in trouble
Feb 24, 2010 | Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
