Question about Treadmill Doctor Cybex Trotter400t 410t 500 Series By Trotter Walking Deck
How to Clean Trotter 535 treadmill and reset message
My trotter 510 treadmill doesn't turn on and just gives off this high pitch sound when turned on
oh, the trotter treadmill that is a workhorse of a treadmill. Question doubled edge. does it start?? or it does not Start. the sound if it does turn on may be coming from the motor which may need new brushes. Trotter is now Cybex fitness. they will have a part to make the repair
Oct 12, 2017 | Exercise & Fitness
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
How To Re-Wax a Wood Deck for a Trotter Treadmill
How To Re Wax Wood Trotter Treadmill Deck
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
I have trotter 535 - the following comes on the screen: error 4 - AC line freq out of spec - does anybody know the fix.
Error 4 is a no frequency lock or noisy line voltage. The most common fix for this to install a dedicated outlet. This is required for most treadmills out there.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Jan 08, 2014 | Exercise & Fitness
Key pad enter + numbers not working trotter 685
adjust the reed switch, test for open or faulty, clean it, and tight the connector fery weel , see the diagram attached
2) replace the batteries old by new ones, and clean the contacts batteries.
3) tight the ribbon cables for keypads, clean it too.
God bless you
Feb 22, 2013 | Treadmill Doctor Cybex Trotter685 900t By...
Trotter 535 treadmill auto start and stop
1) Lube the Deck belt, very well according with your instruction manual maintenance.
2) Lube the rollers bearing too
3) Measure the input voltage motor, if there are The motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. God bless you
Jun 08, 2012 | Exercise & Fitness
I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Dec 12, 2009 | Endurance T3 Treadmill
Treadmill Doctor Cybex Trotter400t 410t 500 Series By Trotter Walking Deck Logo
193 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
