Question about Goodman CKL24AR24 Air Conditioner
Unit outside isnt working
The fan stop blowing, we replaced the motor today. Now the fan runs, then it stops and we are getting hot air coming through the house. Before this we have had 4 burned wires, that was replaced. Also the main circuit breaker keeps tripping. Not sure what is going on with our unit. I need help
  • bills10655 Jun 23, 2009
    Thanks!! How much does that run? Is it expensive? Do you know why the wires keeo burning?
  • 43 Answers
Replace the run capacitor, too.
Posted on Jun 23, 2009
  • FunnyPlumber
    FunnyPlumber Jun 23, 2009
    I suggest you have a qualified technician repair it for you. Run capacitors for a condensor fan motor are not expensive.
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
Furnace stopped blowing cold. 'Stat works, blower works. Went outside, condensing unit fan does not run, motor is excessively hot to the touch. Fan blades spin freely. I pulled the disconnect and...
Hi!!
Replace motor fan and capacitor, it is a very simple task. Turn breaker OFF. Then all you have to do is remove about four screws from the top grill, about four more that fasten the motor fan assembly, unplugg electrical connectors and label them and install the new one and switch fan blades.
No special knowledge is required to perform this job. Cost: about $140 +-.
On the other hand, you call a HVAC technician, they supply the motor and capacitor, otherwise they won't give you warranty. Cost $300+. Look on the Yellow Pages for one in your neighborhood.
Good Luck!! Rate this post!!
Aug 13, 2010 | Carrier 38CKC030 Air Conditioner
My air condition stopped working, that is it blows in the house but the outside fan is not blowing. also on the back of the outside fan motor it was quite hot to the touch, i thought that was hot since it...
The motor gets hot from over amping for various reasons. Nine times out of ten the fan motor needs to be replaced. This really isn;t something that most people can do without proper training. The way it's done on the outside chance that you have the mechanical expertise is, you shut the electric off to the A\C, with a 5/16s driver unscrew the sheetmetal screws at the top of the unit and gently lift the lid and unbolt the four bolts holding the motor turn over lid, pull the electric leads of, making notation where each goes, back the retainer screw off fan blade and remove blade. Unscrew belly band pull out motor. Take this motor to the parts supplier to match exactly the right motor. (All of this is probably academic because almost all supply houses do not sell to the public, it's too dangerous) If you get the motor just reverse everything you did to take the other one out. The best route is to spend a couple hundred dollars and pay a Tech to do it right, It's more involved than an electric or plumbing fix. One other thing to get you by. Get a square box fan and fix it to the top, expelling the air upwards, turn on high and turn on unit, This usually works til a Tech arrives. It may not be as good as normal but it will cool to some degree. Good Luck
Jul 14, 2009 | Heating & Cooling
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
Lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Jun 16, 2009 | Heating & Cooling
External fan stops operating in hot temperatures
Replace the motor on the outside fan, It should run all the time.
Jan 07, 2009 | Heating & Cooling
High Pressure cutoff
YOUR OUTDOOR FAN MOTOR SHOULD NEVER SHUT OFF IN THE AC MODE. IT IS SUPPOSED TO SHUT OFF IN THE HEAT MODE WHEN ITS IN DEFROST. IF THE UNIT IS RUNNING IN COOL AND THE OUTSIDE MOTOR QUITS ,THE COMPRESSOR WILL QUIT SOON AFTER. EITHER THE RUN CAPACITOR FOR THE FAN IS BAD OR THE FAN MOTOR ITSELF IS BAD, IF CAP IS GOOD THEN THE MOTOR IS At FAULT. THE OUTDOOR PRESSURE SWITCH CAN ALSO OPEN IF THE INDOOR FAN MOTOR FAILS IN HEAT OR THE FILTER IS PLUM NASTY in heat OR THE INDOOR COIL IS PLUGGED UP in heat.. THE PRESSURE SWITCH USUALLY TRIPS AT 400 TO 425 SO ITS WORKING CORRECTLY. YOU MAY BE CONFUSING THE ISSUE SAYING THAT THE AIR IS HOT AND COLD INSIDE. IT IS COLD WHEN AC IS RUNNING HOT WHEN HEAT PUMP IS RUNNING IN HEAT BUT ESSENTIALLY not cold or hot if compressor isn't running, but a lot of folks describe the lack of cold air as hot when the compressor isnt running. but it basically is warm or house air temp.you test the capacitor with a capacitor tester or take it to motor shop and let them test it. odds are its a 5 , 7.5 or a 10. it should test within 10 % of rated value . ask for a RESCUE brand replacement motor. they are great ,reversable etc.carefully oil and sand the motor shaft and note exactly where the blade was located in relation to the grill so you get it back just the same. usually they wire up black to a leg of 220 power. white to the other leg of 220 power. brown and brown with white stripe to the capacitor.you can also pull whole fan shroud assembly on some units and take whole thing to motor shop and let them test motor cap, replace and all you do is return to unit and connect two power leads,
Oct 26, 2008 | Heating & Cooling
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
Goodman CKL24AR24 Air Conditioner Logo
292 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
