Question about Saeco Magic De Luxe Espresso Machine
Intermittant brewing Our Magic deluxe was looking good for about 1 year and then...... the grind sounds good, then the nysterious noises (no worries there, just don't know what they are... coffee elves compressing the espresso?, then the pump. The sound is kinda loud for the this part GRRRRRRRRR and the first light of the vertical column of lights goes on, then the second and then the pump sound, which started at "kinda loud"..... falls to a very low grrrrrrrrrr.. and the coloumn lights still go for the full time but nothing comes out. Finishes with the gounds, knocks them out and we got.... nothing. And the odd thing, at some point here, the water light comes on even though it's full. This is intermittent but once it doesn't work, it doesn't work that day at all. Maybe the next day.... Help..... it's too calm around here.... we need coffee... Thanks...
  • Sunward Nov 04, 2007
    Uh oh...adding this to the problem. Just tried the saeco again to confirm the sequence of events.... It goes one light, two lights on the the vertical column and then.....that's it... no more lights. After a time, it stops, ejects the grounds then shows....water light, even though there is plenty of water...
  • danab Dec 12, 2007
    Mine is doing something similar... look at the first solution I got yesterday to check the brew chamber. The flashing light will go away if you dispense water through the hot water / steam nozzle. I read in the manual that happens (flashing light) if you get air in the water line, but I know that's not the case for me cause my water level is fine as well. Running water out the nozzle seems to be the temporary fix.
    I still have steam and hot water, do you?
  • 70 Answers
This one sounds fun.
If the noise is extremely load. The gears are stripped in the gear drive behind the brew group. The gears themselves are plastic.
Bad news is it has to be sent to a service center, replacing and realigning the gears to the brew drive is extremely difficult, and i just wouldn't recommend it being fumbled with.
Even my tech, who has 10 years experience hates realigning the gears. Takes about an hour if not more.
Now...for the reason the gears stripped. Its one of 2 things, but they revolve around the same problem
A puck got stock inside the brew group, and when it made a second cup, both got lodged, and the brew group tried to force it and killed the gears.
Its either that or your coffee is ground too fine for the machine. Yes, the machine can grind it too fine. Actually, anything under 2 is not recommended because 90% of the time it leads to this problem.
I'm sorry there isn't an easier fix, its just the nature of the beast.
Posted on May 25, 2008
Intermittant screeching noise by rear passenger side
Your description makes me worry. If you have a strange, unknown screeching noise coming from the right rear wheel and now there is a burning smell. Please stop using it and have it looked at as soon as possible. There are a few things that could be the cause of these symptoms. Wheel bearing failure, seized brake caliper or frozen caliper sliders, damaged brake line, seized E-brake cable, or improperly installed brake-pads. In any case, if you continue to drive this car, with these symptoms. You may cause a break-down (requiring a tow), or cause a fire. Let me know if I can answer any other questions or how the repair goes, good luck.
Apr 01, 2014 | 2005 Chevrolet Malibu Maxx
My Saeco Magic Deluxe machine just stopped grinding. Everything else seems to be working just fine. I'm assuming it's mechanical and something simply broke but want to ask first and if something broke...
Does it sound like it is trying to grind or is it silent? Listen carefully after pressing the coffee button. If it is silent then the motor has most likely died or the thermal fuse on the motor has blown due to motor overload and overheating.
If you can hear a faint humming, then the grinder may just be blocked (or the dosing chamber located between grinder and brew unit (above brew unit) may be blocked). First try backing off the grind to the coarsest setting. Even if you can't hear the motor, it is worth backing off the grind anyway (easy to do) as you may be lucky. To clear doser, remove brew unit and look up. You shold see a curved trap door like thing that you can swing up to release or poke out stuck ground coffee.
If the machine instantly makes that 'tuka tuka' sound after hitting the coffee button (like it does when it is dumping the coffee after grinding) then the flap or micro switch in the dosing chamber is stuck. Move the dose (grind quantity) adjustment lever back and forth a few times.
If these suggestions don't help then take it to an authorised or expert repairer.
Dec 11, 2010 | Saeco Magic De Luxe Espresso Machine
Magic deluxe does not have enough power
There are a couple of things you can check. Make sure that the dosing lever is not all the way to full charge. 1 click back from full is the best for strong drinks. Make sure that the grind is not too coarse as this takes up more space and is hard to compress. Check the brew units guides inside the sides of the brew unit. They can be clogged with coffee especially at the top by the brew head. Use a Q tip and clean the guides, they don't need to be lubed. And last the brew unit needs to be lubricated where the O-rings and seals are but only there. The big O-ring on the brew head. Inside the receiver tube on the back side of the brew unit (lube inside the piece top to bottom. And finally turn the brew unit upside down.
There is a rd with a wishbone looking thing in the end of the rod. Lube the rod towards the center of the brew unit. This will lube the seal in the brew chamber. Try these suggestions and see if they don't help?
Oct 07, 2009 | Saeco Magic De Luxe Espresso Machine
My Saeco magic deluxe needed the circuits relaoded. I followed the intructions and now my machine tamps first and then grinds the beans leaving me with weak coffee can anyone solve this for me ?
try this.
hit the external dosage button. Its the button on the top middle that controls when you want to put grinds in from the external shoot.
Do not place any coffee in there. then just press the normal brew button. it should brew more or less a cup of water.
then try brewing a coffee like normal and see if the problem fixes.
this happens because there is a little door in the grinder that hits a microswitch that tells the grinder to stop grinding.
This is supposed to happen when the grinder fills the brew group enough to click the microswitch.
Sometimes it does reverse itself like this.
The only other solution would be to open the grinder up and vaccum all grounds out and vaccum the grind shaft above the brew group on the side.
This will cause the door to go back to normal position.
If it doesn't work after that, the door or microswitch has gone faulty. But that is an extremely rare situation.
Hope this helps.
Oct 03, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco coffee machine
make sure that the brew group and door are close or dump box ect
Jul 08, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic de luxe not grinding beans
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
May 05, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Brewing stops mid cycle
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
May 16, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
158 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
