Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door lifted up but will not go back down and the remote quit working.
    President:
  • 3,197 Answers
If your door is in the open position the trolley is probably jammed against a bolt just in front of the motor unit. Remove that bolt and then run the opener until the door is closed. Now on the side of the motor unit you will find a control labeled 'up limit'. Turn this about 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Posted on Jun 23, 2009
My fixed garage door opener opens fine, but only closes if it is held down. My remote garage door openers do not work at all. I replaced the sensors and they appear to work fine. I tried to reprogram the...
If the sensor is working right, that leaves the downward force sensor tripping. First check for track obstrucions by manually moving the door with the lift disengaged. If door works without excessive force, then increase the force sensor of the lift a bit.
Jun 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cannot reset remote to garage door opener Sears craftsman 139.53681B
If you are sure the battery is good then try to program the remote by holding the button down on the remote and then pressing and immediately releasing the smart/learn button. If this doesn't work and you have another remote that does work then the remote has quit working.
May 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Automatic side door will no longer open with remote or console button in car. Also, both side door's locks will not pop up using all of our 3 remotes (1 door is automatic, 1 is manual). Lastly, the back...
Did these doors quit at the same time or over a period. It seems that the actuators for the locks have gone bad. With the mentioned doors, that's a lot weight for the actuators to unlock and pop open. With the remotes and console not working , that's more reason to think the actuators are the problem.
May 02, 2010 | 2002 Chrysler Town & Country
Have sears garage door opener it lifts allright but cant close unless you hold the wired pad. works ok up with the remote just jumps a little when you push down button will not close with remote.
Check your door sensors and make sure they are pointed at one another. Each of them has a small light that should be lit when they are properly aligned. Tweak them if necessary. If you can't get both lights to come on then one of the sensors has quit working.
Jan 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote control 139.53681 to Garage door opener model 139.53663srt2 stopped working. Changed battery but still does not open door. Are there any other steps we need to do to configure the remote to open the...
You can try programming it but if you have another remote that works and this one doesn't it probably just quit on you. To try programming it hold down the button on the remote and then press and immediately release the smart/learn button on the back of the motor unit.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift gate door will not lock or unlock
Check out the following link, it is a step by step process to getting the fix...
http://www.chefseattle.com/blog/site-news/suburban-rear-liftgate-wont-unlock-how-to-fix/
Jun 13, 2009 | 2008 Chevrolet Suburban
Door locks quit working
check battery in the remote
May 10, 2009 | 2006 Chevrolet Tahoe
Hydraulic lifts on back door quit working
Sorry you can not repair the hydraulic life, your going to have to replace it. You can buy new ones at the Auto Zone or Parts Source and both parts store can give you the how to do the job your self.
It's only going to take you less then 5 min to change one side at a time with the use of a flat head screw driver.
Good luck and hope this helps, most of the time the parts person can help you change the back door lift.
May 05, 2009 | Volkswagen New Beetle Cars & Trucks
2004 GRAND CHEROKEE DOOR LOCKS
Ground wire (black) open between drivers door conector and door pillar due to flexing. Locate break and solder in some extra wire to relieve the stress when the door is used.
Sep 15, 2008 | 2004 Jeep Grand Cherokee
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
131 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
