Question about John Deere Garden
Mower runs fine until I engage the blades then bogs down
  • 109 Answers
SOURCE: Mower starts but when the blade is engaged it stalls
Check the pulleys on the deck...one of them is jammed or rusted to the point that will not turn.
Posted on Apr 16, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Posted on Nov 24, 2010
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Mower runs fine until I engage the blade. it then bogs down
A couple possibles I can think of:
  • Carburetor main metering circuits are clogged. An unload engine primarily runs off the idle circuit.
  • Blown head head gasket or other loss of compression.
Mar 31, 2015 | Craftsman Garden
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Troubleshooting
need govenor adjustment and throttle adjustment have to take in 60.00
Sep 04, 2014 | Cub Cadet Garden
Garden Logo
29 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
