Question about Cuisinart SM-55 Stand Mixer
Why my cuisinart stand mixer wont mix
My mixer was working just last time w/o problems, now it turns on but won't keep mixing. Will make a sound, 2-3 turns and stops. It's 6 years old, so past warranty. Any ideas what can I do?
  • 857 Answers
SOURCE: Sir, I am the owner of a Cuisinart SM-70BC 7-Quart
Follow these steps to find out the problem else call Cuisinart { 1-800-726-0190 } for help :
•1
Remove the back cover by removing the small Phillips screw at the top of the back cover.
•2
Place a rag or cloth over the spring to keep it from moving.
•3
Plug in the mixer.
•4
Move the switch lever to "Stir." This may or may not start the motor.
•5
Turn the two adjusting screws counterclockwise evenly until the planetary turns approximately 60 times per minute.
•6
Test the planetary by holding a right hand finger lightly across the beater shaft. Count how many times the shaft touches the finger in 15 seconds.
•7
Turn the two adjusting screws until the shaft brushes the finger 15 times in 15 seconds.
•8
Lock the two lock nuts using an 11/32" wrench. Check the speed again.
•9
Make further adjustments, if necessary, without loosening the lock nuts on the control board. Unscrew the two adjusting screws.
•10
Move the planetary to speed 6. At this speed, the planetary should turn 180 times per minute. Check speed as you did for the first speed. The planetary will brush your finger 15 times in 5 seconds if the speed is correct.
•11
Turn the adjustment screw at the bottom of the control plate if the speed is less than 15 times in 5 seconds.
•12
Check the revolutions again. Keep adjusting the screw at the bottom until the correct speed is reached. You don't need to lock down this screw.
•13
Test all speeds from "Stir" to #10. If "Stir" and #6 speeds are properly adjusted, the other speeds should be correct automatically. If you notice a definite change in speed between #8 and #10, you have adjusted the mixer speeds correctly.
•14
Replace the back cover and screw in the back cover screw.
Posted on Sep 25, 2010
welcomejee
  • 10594 Answers
SOURCE: My Cuisinart stand mixer won't
It sounds Motor Control Board got problem as you hear relay click but motor does not get power to rotate from motor control board.
It is electronic hardware failure issue, its not user level repair and professional can do it.
Click Cuisinart Contact link to find out nearest repair center in your area.
Hope these info will help you.
Thanks.
Posted on Oct 09, 2010
  • 10 Answers
SOURCE: my cuisinart 5.5 stand mixer
Make sure the plug is securely plugged into the wall.
Next, remove and reattach any mixing arms etc that may be attached to the mixer. Having one not attached properly can result in a start, start.
If problem persistes make sure the speed is reset.
If problem continues, here is an excerpt from the user manual found here.
http://www.cuisinart.com/share/pdf/manuals/sm-55.pdf
Problem: Your stand mixer has an
overload protection device and if
overloaded, it will shut down to protect
the motor.
Solution: In the unlikely even that this
happens:
• Turn off and unplug the unit.
• Reduce the load by removing some of
the ingredients, and allow the mixer to
stand for a few minutes.
Plug in and reset the speed. If the
stand mixer does not start when you
press the on button, allow the unit to
stand for additional time.
If you are still having trouble, the product comes with a 3 year limited warranty, so if you're bought it within the last 3 years it may be covered.
Good Luck!
Posted on Mar 01, 2011
SOURCE: The flat mixing paddle is stuck in the mixer and
Here's what really happens. The hook has a shaft screwed into it with bayonet fittings that lock into the mixer. The shaft has a locknut where it screws into the hook. If the locknut becomes loose then the shaft can screw in too far making removing from the mixer almost impossible. Try to get a slim wrench onto the locknut and loosen it off enough to allow the hook to be unscrewed. After the hook comes off, move the locknut down the shaft until the whole assembly can be removed from the mixer. Re-attach the shaft to the hook making sure that the exposed portion of the shaft is long enough to allow for easy removal from the mixer. Tighten the locknut and you will never have the problem again.
Posted on Sep 02, 2012
Alleluia
  • 69 Answers
SOURCE: Cuisinart Broken parts
Cuisinart SM 70 Parts List and Diagram eReplacementParts com
you should find all your replacement parts here. Best wishes
Posted on Feb 26, 2014
Attachments not turning. Small screw located next to accessory power port unscrewing when mixing.
Paula, Put a drop of loctite on screw and insert securely, let sit to dry 24 hours to cure.
press the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | Cuisinart Cusinart 5.5-Quart Stand Mixer
Kitchenaid ksm90ww stand up mixer while mixing my aunt put in another mixing tool and it just stipped mixing wont turn on nothing I assume she blew the motor but does anyone know if theres a reset button...
It sounds like stripped gears, does the mixer still turn on? The beater just wont spin anymore?
If that is the case the worm gear probably stripped out, that is part number w10112253, or for a quicker easier fix you can get that gear in an assembly for a couple more dollars, that would be part number 240309-2.
Here is a link to those parts on our website:
http://www.mendingshed.com/kawormgear.html
http://www.mendingshed.com/kitchenaidgearassy.html
Jan 16, 2014 | Food Mixers
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
My cuisinart 5.5 stand mixer when you press the on button it starts for a second then it stops.
the motor.
happens:
Good Luck!
Mar 01, 2011 | Cuisinart SM-55 Stand Mixer
4 1/2 quart kitchenaid mixer head jumps when mixing
Adjusting the screw didn't work for me the first time I tried it.  I was afraid of loosening the screw too much, and so I didn't turn it far enough.  Turning the screw counter-clockwise until it stuck out several millimeters finally worked.
Mar 15, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid wobbles when mixing
The "wobbling" sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Also, leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Dec 24, 2008 | KitchenAid K45SS Classic Stand Mixer
Loud and throws flour all over
Do you find the motor running too fast at the lowest setting? Then you need to bring it to someone to adjust the low speed setting. If you are preparing double batches you are over loading the mixer and/or using too fast a speed setting to mix. Don't try to double recipes just because the bowl can handle the volume, the motor cannot and will not last very long if stressed mixing dough frequently.
Nov 13, 2008 | Betty Crocker 340 Watts BCF1250 Stand...
Overloaded Motor
Are you mixing at a high speed. For bread, you shouldn't go above a '2' setting on most of the mixers and keep the time fairly short -- more isn't needed.
Sorry if this is redundant, but info posted to another problem works here as well:
KitchenAid has one of the best user forums of any company as far as I'm concerned. The participants are great and the monitors are exceptional (some of the best problem solvers you are likely to run across). You may find your experience already has a thread, if not, post it. I checked in and they seem to have added a video library that has some of the topics I've seen posted at this site.
http://www.kitchenaidconversations.com/
Oct 29, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Cuisinart SM-55 Stand Mixer Logo
82 people viewed this question
Top Cuisinart Food Mixers Experts
Ross Keen
john h
Are you a Cuisinart Food Mixer Expert? Answer questions, earn points and help others
