Question about Panasonic Office Equipment & Supplies
Why is the filter warning light on DZ8700 panasonic 10k projector
Loose filter warning
Most projectors have a safety interlock switch installed on the lamphouse door and in the filter cavity. They are there to keep the unit from operating if one or the other aren't present. I'm not familiar with your exact model, but I've seen the lamphouse interlock switch in several Panasonic units come-loose, and slide to the point where the pin on the door doesn't push the switch any more. I would suggest looking around your filter for such a switch. The one in the Panasonic is behind a round hole, and is 'pressed' by a plastic pin on the door. Your filter may be similar. Hope it helps. :)
Apr 28, 2013 | BenQ W500 Projector
Unit powers up then shuts off after a few seconds
The problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a powericon1.png supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so, you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Apr 07, 2013 | Sanyo PLC XP30 Multimedia Projector
Panasonic projector dust filter warning
you need to clean dust filter and replace filter if required
it depends on which model u are referring to
this message is seen generally in the hi end models only - DLP range in access of 4000 lumens
Dec 25, 2012 | Panasonic Office Equipment & Supplies
My data projector eiki LC-Xb23 goes off without warning and the warning light is flashing
If the power light & warning light both flash red, this indicates that the projector is overheating. Once the projector has cooled down the warning light would continue to flash red and the power light would be solid red.
You should clean the air filters.
The filters are located on the underside. Disconnect all cables and invert. remove the 2 air filters located at the front and rear by pullingthe latches. They are both rectangular in shape.
Being very careful not to damage them, you should rinse the dust out and leave them to dry fully before replacing them in the projector.
This should cure the problem.
Feb 17, 2011 | Eiki LC-XB23 XGA LCD Projector Multimedia...
PT-L785U Projector
if the lamp warning light is flashing, this indicates a defective ballast (lamp power module). if the lamp warning light is lit steadily, then the lamp would be at fault.
Oct 13, 2008 | Panasonic PT-L785U Multimedia Projector
Lamp replacement
Hi there
There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
Sep 16, 2008 | Panasonic Videoprojector PT-LM1E...
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
