Question about Singer 4423 Sewing Machine
Where is 6235 singer feed dog adjustment located?
  • 29 Answers
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
Posted on Jul 14, 2007
  • 69 Answers
SOURCE: feed dog problem.
Open the bobbin case door and there should be a lever sitting off to the right. It moves from left to right. For the feed dogs to be in the up position the lever should be to the left.
Posted on Mar 01, 2009
louislevel_2
  • 374 Answers
SOURCE: Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Posted on Apr 03, 2009
  • 43 Answers
SOURCE: How do I raise and lower the feed dog on my singer
On your Singer, you don't actually raise / lower the feed dog. Instead you attach a "darning plate" (which should have come with the machine) which covers the feed dogs so they do not come in contact with the fabric. See a page from the owner's manual using this link within my web site: http://www.sewvac1.com/Singer3080_Feed_Drop.pdf
Posted on May 06, 2009
SOURCE: Looking for a free download of Singer Sewing Machine 6235
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
Posted on Feb 26, 2010
Singer 6235 - the fabric is not advancing regardless of stitch length or tension
Could be any of a multitude of reasons.
Check whether the feed dogs are actually rising 'above' the needle plate. If not, then they may be in a dropped position used for darning and free motion quilting.
Sometimes the feed dogs and the mechanism underneath is jammed with lint and debris. Make sure the dog teeth are well cleaned. Also check if the tips of the teeth are worn. Also verify that the needle plate is flush with the free arm--if it is raised, it will prevent the feed dogs from doing their job.
The other thing to check is whether the machine has a presser foot pressure adjustment. Some machines have it, others do not. On newer machines, it is usually a dial somewhere around the left side of the head or toward to top of the head. On older machines, unfortunately, some are simply a big screw head on the inside of the case directly above the presser foot bar. It basically applies more pressure to the presser foot, which in turn applies more pressure to the feed dogs. The problem will usually show up when sewing either very heavy or very fine fabric. Perhaps trying a different presser foot will make a difference.
I don't know what is the highest number the stitch length goes to on your machine, but a #2 stitch length is pretty short on mine. Try setting it higher.
Sewing Machine Presser Foot Stuck
Singer 6235 User Manual
Nov 19, 2017 | Singer Sewing Machines
Singer sewing machine model 7005, dog feed is not working. Where is the lever to adjust the dog feed.
The Singer Imperial 7005 does not have a feed dog lever. Instead there is a feed dog cover that gets placed over the needle plate. To remove the cover, raise the needle and presser foot. Open the slide plate, then lift up the front edge (closest to the bobbin) of the cover. Then pull the feed dog cover away from the sewing machine.
See page 10 of the manual; it's page 12 of the PDF. The manual is available at the Singer manual search page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/676_7005.pdf .
I hope this helps.
Sep 13, 2017 | Singer Sewing Machines
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
6235 singer ! How do I raise feed dogs ???
According to the manual, there is an accessory that covers the feed dogs. (Shown as an accessory on page 4.) So the feed dogs should not raise or lower other then during normal sewing action of moving the fabric.
Singer 6235 User Manual Page 24
Singer 6235 User Manual Page 6
Dec 27, 2016 | Singer Sewing Machines
How do I get the feed dog up on model 6235
The feed dog for that machine is NOT designed to be raised or lowered; instead a cover is put over the needle plate. You might want to remove the needle plate--it's designed to be removed to access the bobbin case--and see if you can pop it up again. On models that DO have the ability to raise and lower their feed dogs, once it has been lowered, if you press the dial or lever to raise it, it won't raise until the hand wheel is turned one or two times.
Sep 29, 2014 | Singer Sewing Machines
Can not locate feed dog switch for model6233
the question is under the singer sewing machine category, so I look up a manual for a singer sewing machine model 6233, the feed dog information should be in there. http://www.singerco.com/uploads/download/1314_6233.pdf
Jan 25, 2014 | Singer Sewing Machines
Singer 6235
feed dog need to adjust more up
Nov 07, 2013 | Sewing Machines
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
h! there,
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Singer 4423 Sewing Machine Logo
131 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
