Question about Electronics - Others
How do i find a wiring diagram for a crate rfx120 retrofex?
The circuit board on the amplifier is wired incorrectly and needs to be properly wired
  • 2,509 Answers
Wiring the circuit board i need a diagram
wiring diagram for what brand? is the circuit board located in the pump housing or in a separate box?
Rod
US Parts Center
We locate the "seemingly" impossible...
888-521-6183
Jan 20, 2013 | Home
Buzz across all channels in crate rfx120
I also have this issue. Same crate combo amp. There is a loud buzz emitted only when there is a cable plugged in. Cables and instruments checked good, only possible issue is inside the input of the amp. Popped it open, solders and connections were intact and appeared solid. Anyone have a guess as to why this is happening?
Feb 12, 2012 | Crate Music
Three button crate footswitch wires need to be refastened. I need a wiring diagram.
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Sep 16, 2011 | Crate Cfs3
It will not work what colud be wrong
its a crate. 60% of all crate amplifiers go back on defects. take the top screws out and slide out the chasis, look at the fuse and determine if its toast. if the fuse is good, get a new amp. if the fuse is bad replace it and you should be good. the circuit board will have the correct fuse to be used printed on the board.
yostamplifier.com
Dec 30, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Noisy/buzz
Usally a ground loop isolator will fix that problem. It plugs into the RCA's between the radio and the amp.
Try to reground the amp in a different spot.
Or run a refrence ground from the deck to the amp next to the remote turn on wire. (still keep your main amp ground hooked up)
DO NOT run your power wire next to the RCA's, that will induce a field which in turn can cause that buzzing sound.
Jun 03, 2009 | Crate SPA1600 Power Amplifier - SPA Series...
Wiring
Autozone.com does have the wiring diagrams for your vehicle.Just as a warning as I don't know the level of your skills,if you are not familiar with reading schematics or if you have little to no experience wiring I would have a professional do this,it's a very complex circuit,and if done incorrectly could cause irreprable damage to the control circuits or your computer.
May 25, 2009 | 2004 Mazda 6
Crate gtx 65 guitar amp mains hum
I had the same problem on my VTX65. I noticed it would oscillate with different effects so I removed the effects module. Problem solved. Now it's dead quiet. I use a Digitech RP500 so removing the effects module was a non issue.
May 19, 2009 | Lexicon LX-7 7-Channel Amplifier
Solid State amplifier problems
I would look for crossed wires or shorts on the board itself as a result of overheating. They will look like toasted circles around the pins of the board. You may not have been the first to open the amp and make a repair.
Apr 30, 2009 | HHB Radius 50 Tube Amplifier
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, techmail@loudtechinc.com.
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Electronics - Others Logo
946 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
