Question about Lowrance Boating
How do i get my water temp. to work. just keeps blinking 32 deg.
4 Suggested Answers
Gort007
  • 1187 Answers
SOURCE: the temp says 16 deg F, how do I get the temp back
You want the freezer to be below 32 degrees.
Ice cream will thaw at 32 deg F.
Bacteria can survive 32 deg F.
16 deg F is normal for freezer.
Zero degrees F is the best setting for the freezer.
Refrigerator should be 40 deg F.
http://www.ag.ndsu.edu/pubs/yf/foods/fn403.pdf
Posted on Oct 01, 2009
Benimur
  • 6966 Answers
SOURCE: The fan goes on at about 215-217 deg F. The temp.
Hi and welcome to FixYa,
To my understanding, the cooling fan is activated by the ECM. This is done by switching the yellow/black wire to ground. The activation is triggered by the coolant temperature sensor that feeds signals to the ECM. Ideas to consider:
  • verify integrity of connections of coolant temperature sensor (purple/black & purple/green wires) to the ECM;
  • check, clean or replace the coolant temperature sensor itself;
  • bypass ECM and install a manual override switch plus dual reverse protection diode on the 2 yellow/black wires from the cooling fan wire connector.
Good luck and thank you for asking FixYa.
Posted on Nov 12, 2009
  • 587 Answers
SOURCE: Chronotherm III displays 32 deg for room temp,
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on May 12, 2010
Explain the different unit of temperature and give the relation between them
You have the Celsius Scale characterized by
Freezing Point of water :0 deg C
Boiling point of water : 100 deg C
The Fahrenheit Scale characterized by
Freezing Point of water :32 deg F
Boiling point of water : 212 deg F
If F is the value of a temperature on the Fahrenheit scale, the corresponding temperature on the Celsius scale is given by
C= (5/9)*(F-32)
If C is the value of a temperature on the Celsius scale, the corresponding temperature on the Fahrenheit scale is given by
F= 32 +(9/5)* C
Nov 25, 2013 | Computers & Internet
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
I do not have the user guide for my A.O.Smith EES52 - a 50 gallon electric water heater, so my questions is; are there one or two heating elements in the tank? If two, where are they located and which...
Your water heater has two heating elements. The Two elements work in tandem to bring the water up to temp. then the top element keeps the water at temp. Here is a >>> link
Aug 19, 2011 | Water Heaters
Have an AD2-P siemens smoke duct detector that is rated at operating temps from 32 deg to 100 deg. Now is this the range temperatue that the inside of duct can be before alarming? The application that we...
Operating temp are the control limitation. U Have to keep air flow whiten those boundaries. As to the humidity, no problems as long as you do not go above 85% RH and make sure no condensation occurs. Regards Guy
Aug 12, 2011 | Heating & Cooling
Hello what temp should i have my fridge/freezer at the freezer unit is working but the top is warm, thanks, Sheryl
Sheryl -
Most manufacturer's suggest 0 deg F for the freezer, and 34 deg F for fresh food compartment. You determine the fresh food temperature by filling a 6 to 8 oz glass with cold water and placing a thermometer (capable of reading 32 deg F) in the water. Place the glass & thermometer on a shelf in the fridge. Allow it to assume the temperature on the fridge and hour or so. The glass of water is to minimize rapid increase in temperatures seen when the door opens.
Make your adjustments from there. Allow temperatures to stabilize for up to 24 hours if the fridge is full, much less if empty before making additional changes.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Refrigerators
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
ASU9RLS/AOU9RLS unit Froze outside/ won't defrost
The drain had pine needles clogging the drainb so it couldn't drain.
In 2 months.... Thanks anyhow!
Jan 05, 2010 | Fujitsu Electronics - Others
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Boating Logo
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
