Question about Canon PIXMA MP495 InkJet Printer
I fixed paper jam but still get error E03
MP495 had a paper jam and I pulled it out, turned it off, reset button, and still the new paper goes in about 1/5 of the way and eventually I get E03 again.
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
  • 358 Answers
SOURCE: error e03, but there is
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Posted on Nov 03, 2010
SOURCE: Canon PIXMA MP495 Error Code
Hi Taco
I have the same problem. Did you find a solution?
Posted on May 28, 2011
  • 29 Answers
SOURCE: I have a cannon Pixma
I believe that you tried to turn the printer off, then on. Did you? If so, and the problem persists, I belive that the jam sensor became damaged.
In a last instance, you can turn off the printer and see if you can turn a little (with your fingers) the roller that pulls the paper.
Posted on Jul 20, 2011
  • 88 Answers
SOURCE: My MP495 will not pull the paper completely
your printer Cleaning
Posted on Aug 23, 2011
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
What is code error e03
Printers & Copiers
Code error E03
Nov 14, 2014 | Office Equipment & Supplies
Toshiba e studio 212 copier. Gives error code e03. Paper has been cleared and no particle inside, all sensor in place. Still gives error e03. What to do?
Search carefully onto the fuser cover for the actuator for exit sensor.
There is a spring that moves the actuator into normal position when the paper has passed. If it seems the spring is out from the actuator it will think there is still a paper jam. The best bet would be to call a service company to come out and make repairs if you are unable to get this spring back into place. After resetting the spring into the correct location, restart the machine and see if the problem continues. If it works and then goes into error mode again, it is likely this spring and or senor will need to be replaced.
Good luck.
May 13, 2014 | Office Equipment & Supplies
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
Apr 03, 2012 | Canon Office Equipment & Supplies
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
Canon printer mp495 error code e03
* E03 error means that it may have something to with a clogging of the paper feed sensor.
try to clean every theing in the paper path and check if there is no sensor broken or bend or stuck
Nov 10, 2011 | Office Equipment & Supplies
I have a cannon Pixma Mp495. THis morning some paper that was wrinkled went through it when it was printing. THere was not any paper left in the printer. I did pull a sheet out the top that was stuck...
Jul 20, 2011 | Canon PIXMA MP495 InkJet Printer
Canon PIXMA MP495 InkJet Printer Logo
21 people viewed this question
old marine
old marine
