Question about Garden
Bay boy czt. Lawn mower battery draining problems
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
If you have an electric PTO ( blade clutch ) you need no less than a 450 cranking amp battery...
you didn't mention the engine but I am assuming it has a B&S v twin ??? check and make sure you have battery voltage at the red wire at the voltage regulator... if yes, suspect it's bad, if not, look for a blown fuse
Posted on May 17, 2014
SOURCE: 2 cycle oil to gas ratio for Lawn Boy mover Model 10324
32 parts gasoline : 1 part oil
Posted on May 06, 2009
  • 208 Answers
SOURCE: can't get my lawn boy started
check for a faulty wire to the engine kill switch it may be contacting the ground
Posted on Jun 22, 2009
  • 413 Answers
SOURCE: mower starts but boggs down and then dies
Sounds like the air filter media is full of muck.
You need to clean it.
Everything should then be fine....
Posted on Jul 02, 2009
  • 404 Answers
SOURCE: lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
Posted on Jun 01, 2010
  • 273 Answers
SOURCE: just bought a 10 year old lawn boy 2 cyl mower fro...
What is the model number of the mower? The picture posted by your question shows the 4 cycle Briggs & Stratton powered mower.
Did you run it for a long time? Five years would allow all gasoline to evaporate, but not the oil. You might have double the oil in the system.
If this is has the Lawn Boy OMC motor, excessive smoking can be caused by:
a worn crankshaft seal
a carbon-fouled muffler
carbon-fouled piston exhaust ports
a defective fuel primer circuit (sometimes disconnecting the primer button hose will stop the smoke ...carb work needed if this is it)
a fouled plug (causes incomplete combustion... and smoke)
weak reed valves (a constantly wet air filter is a sign of this)
Posted on Jun 09, 2010
Where can I find a troubleshhot guide for a lawn-boy cordless walk power mower model 10123
Batteries need to be kept warm and charged,on a regular basis,this is where a "Float Charger" comes in handy to monitor battery voltage while in storage ,I'd bet the ranch your battery is toast,but any auto parts store could LOAD test it for you ,Good luck !
Jun 08, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Will not start after changing the blade
what side did you tip it to did oil drain into the carb did gas drain into the cylinder flooding it out remove the spark plug and look pull the engine over with the plug out and that can push it out
Apr 25, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have a Lawn Boy silver series self propelled mower, model number 10324-8902967 that leaks fuel from the exhaust under the mower deck after I have finished mowing and turned the engine off. I will drain...
sounds like the needle valve is not seating some have a rubber tip on needle some have it in the seat but the fuel we now have rot the rubber never store with fuel if possible
Apr 02, 2012 | Toro Lawn Boy Self Propelled CARB Walk...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Unable to locate oil drain plug in briggs stratton 650 series lawn mower
Open the spot where you put the oil in.Now turn the mower so that is comes out the hole it went in.It can be messy so use a large bucket.
May 30, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
I have a lawn boy 10335 push mower that sat unused for several years. I added new gas and went to start it up it spring a gushing leak out of the carburator. There is a small red hose that the gas was...
The needle and seat are bad in the carburetor. You need a tecumseh part 631021barterjoe_2.jpg and it might be recommended to get a service manual. They are inexpensive at a shop like www.arcolawn.com
good luck
Joe
Feb 13, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Drain sump oil
What kind of oil did they put in? The drain is on the lowest part of the engine, a small plug either in the block or at the end of a pipe, just find a container to fit under there and pull the plug, then fill it back up with the fresh oil. Don't forget the plug!
Feb 18, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Can't get my lawn boy started
Jun 22, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
