Question about Mtd 22" Yard Machine Push Mower
What is the gap for spark plug in briggs and stratton yard machine?
    Champion:
  • 279 Answers
Contact MTD if your manual doesn't cover this, or buy a shop manual, or look up your engine on the Briggs & Stratton website.
Posted on Dec 22, 2014
  • 15 Answers
SOURCE: briggs and stratton lawnmower 4horse power engine needegap specs on coil and points
That's easy man! You will always hear, "You sir, need to gap this or that at EXACTLY .00071542 inches per square meter".
The actual "poor boy fix"-
Put your magneto back on there, and stick a business card from your wallet in between it and the rotor. Let the magneto pull itself to it, you center it, and give it just a hair of breathing room (to slide the card back out). Tighten 'er down, and you got it.
1.- If you can't pull the card out, it is too tight.
2.- If you pull the card out easily, too loose.
3.- JUST enough to pull it out, and have it drag just a bit on the way out is JUST ENOUGH!
Remember, on 4-strokes, they ARE forgiving, and can do miracles even if you try your best to destroy them.
Posted on May 30, 2009
  • 10 Answers
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
01fordeb
  • 1033 Answers
SOURCE: Briggs & Stratton 6hp yard machine with 21inch
The fuel bowl needs to be removed and a new float and needle needs to be installed. The float "floats" in the gas bowl raising the needle, letting fuel into the carb. The repair kit cost about $5 and easily replaced. The float is attached with a pin and the needle fits on the float.
Posted on May 13, 2010
rycgl
  • 1545 Answers
SOURCE: HI there, I got
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Posted on Jun 05, 2011
hunter19_46m
  • 7482 Answers
SOURCE: weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Posted on Jun 13, 2011
What is the spark plug gap for Briggs 20.5 hp
For a proper answer more info is needed. Here's a Briggs site that has spark plug gaps listed. Gap is not hyper critical for running.
.030-.045 will work. The only time I've seen gap matter was when it was too close like .005, the engine wouldn't run.
What is the right spark plug and gap for my small engine Briggs Stratton
Sep 21, 2017 | HP Garden
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Yard Machines 21hp briggs & stratton, 46" cut riding mower. What is the spark plug gap?
Most gaps on the plugs are approximately ..020 to 030 for all Briggs motors.
Most plugs are pre-gapped when you purchase them.
Use this link to be sure:
http://www.briggsandstratton.com/us/en/support/faqs/identifying-the-correct-spark-plug-and-gap#SparkPlugChart
Jun 26, 2015 | Garden
BRIGGS AND STRATTON 550 SERIES
Identifying the Correct Spark Plug and Gap
What is the correct spark plug and gap for my engine?
Due to the variety of engine and equipment configurations, your best source for spark plug information is your engine or equipment Operator's Manual. However, the following general guidelines will get you pointed in the right direction.
This guide provides the common spark plug part numbers used in our L-Head and Overhead Valve engines. For information regarding the service/replacement of spark plugs, please visit our Servicing the spark plug FAQ. Please be aware that the size/shape of the spark plug varies depending on engine design.
Briggs & Stratton L-Head Engines
(also referred to as Flat Head or Side Valve Engines)
Sep 29, 2014 | Briggs & Stratton Garden
Briggs & stratton engine 500 series 158cc + spark plug gap
Look up your engine on the Briggs&Stratton website.They have all the specs. Or call MTD.
May 18, 2014 | Mtd 22" Yard Machine Push Mower
What spark plug does my yard man lawn mower take? here are the numbers off the engine 110602-0131-e1
According to my data, you'll need a Briggs and Stratton Part No. 692051 for that machine. Cross reference to Champion Plug RC12YC. Note that this plug shows a recommended gap of only .020, as opposed to the .030, most Briggs plugs use. Best of luck to you.
Jun 29, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Spark plug gap fpr a
Typical old Briggs flathead "L-Head" engines require about a .030" plug gap.
Jun 05, 2010 | Briggs & Stratton Garden
Mtd 22" Yard Machine Push Mower Logo
59 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
