Question about Kenmore Elite 45986 Front Load Washer
My kenmore elite oasis keeps stopping on spin and flashing ul it is a top loader king size capacity
  • 15,935 Answers
UL = uneven load.
Re-distribute clothes and re-try.
If still no-go... the load balance sensor is likely to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have a kenmore elite total care flex king size capacity plus quiet pak2 oasis that makes loud noises like a airplane when its in the spin cycle Model #110.28032701 which parts should be change?
If the washer is roaring during spin, the bearings are bad and you will need to replace the outer tub assembly.
Here is the part to order.
The part comes with a 365 day, any part, any reason return.
Nov 03, 2012 | Kenmore Washing Machines
Kenmore elite 110.2706 unbalanced load problems
I have the same problem with my washer though it is a Maytag. the part that grips the drum to spin it is stripping, (and not properly grabbing). Repair man said to just get a new but I'm sure if you find a dedicated enough repairman he may be able to replace that part. The repairman said to replace mine because it was over 8 years old.
Sep 08, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
How do you solve the balance problem in the kenmore elite oasis even with no clothes it in
Try running with no clothes? If still shows UL when empty running, your machine needs service. P.S. use HE detergent or else.
Aug 27, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washing machine has error code "UL" while in rising cycle and stop. Can you tell me what is the problem and how to solve it.
My Kenmore Elite Oasis washing machine will drain but not spin and it keeps jumping back and forth to different time cycles. It continually reads "UL" and I keep trying to adjust and balance the load but it does not help.
Jun 25, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis starting to show "UL" and immediately stopped working. How do I fix this issue?
UL = Unbalanced Load
re-distribute the clothes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Oasis HE model 110.28082700. On any setting, it will run though until it reach the spin cycle and then it drains, stops, beeps and flashes the ul message and shuts down with about 6...
Kennmore Oasis washer; I just replaced the lid locking mechanism (8563937) with the upgrade (W10059230) because of "LU" Error code. First test run and now "LD" error code... So not sure I will buy another Kennmore in the future...
Jul 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
513 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
