Question about Exercise & Fitness
Diagram of ateries in the legs - Exercise & Fitness
Aterial fibrilation self help
The only way to Stabilize a heart beat is with a pacemaker.
Mar 25, 2014 | betterbooks.info A Patients Guide to Heart...
Need wiring schematic for Wesco Model 2100 Electric Furnace (wiring diagram)
82106c19-5c06-486e-9f9a-3e04a0a81160.pngfafba6f2-5eeb-4990-a3c3-1b3f3ae5dbc6.pngThat unit is very small with every component within 3 feet of the pigtail/power cord.
A electric heater has heat strip/s
a switch and 2 thermal limiting devices, 1 auto resetting, the other not resettable or serviceable by the user, tending to not be an economically viable option.
There are 2 hot legs of power and an earth/ground wire feeding any home or most businesses, every wire in every unit is either 1 of the 2 coming in to the building, Line 1 and Line 2.
Now if you know the sequence of operation and can recognize the components, thus locate them and are familiar with each as to what terminal is what, there is no need for a wiring diagram to tell you that 2 legs of power feed each load, be it high, low voltage, AC or DC polarity.
Every circuit requires 2 sides/legs of power Line 1 and Line 2.
Beginning on Line 1 go through the switch, to the load/device,
and from the device/load we return to the opposite side/leg of power from which we began.
Now if you do not know this and do not recognize the components thus cannot locate them other than tediously following both legs of power all over to where you know it must be anyways! as the unit in no way resembles a wiring diagram I see no use for a wiring diagram for those who know or do nor know the trade.
Oct 10, 2013 | Heating & Cooling
Connection diagram for diehl t85 typ 600
1) Copy following links.
http://waterheatertimer.org/images/Deihl-T85-600-wired-for-208-230-Volt.jpg
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#T85
2) 3-pin 5 amp service has 2 hot legs (wires) located across from each other on outlet.
Interrupt one hot wire and circuit turns OFF.
However live power potential still exists on remaining hot leg.
3) To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
Jan 05, 2013 | Diehl Hardware & Accessories
How do I install on/off switch on Skil Saw 3400
It just pushes in and out. It is held in by plastic legs on the top and bottom of the switch. Reach behind the switch and squeeze on the top and bottom legs to compress them while you push the switch out. The new one will just snap into place as you push it in. Here is a parts diagram if it helps.
Skil 3400 diagram
May 09, 2012 | Skil Saws
Engine to body or any other ground that I may need to check
BATTERY CAN ALSO DRAIN THROUGH BAD STARTER SOLENOID.
Aug 01, 2010 | 1993 Ford Crown Victoria
I need a wiring diagram for the kenmore 75101 thru wall a/c unit a complete diagram all componets listed
The pigtail cord has a hot leg and neutral for 115 volts, or if 230 volts , 2 hot legs of 115 volts & and a ground. The Hot leg (if one) is routed through the switch. The switch seds power to the compresor and fan motor. The neutral or other dside of power is the side all loads will terminate to have both sides of power as a AA batt in a flashlight, both ends of the batt must be present, as this is all there is and you willneed to trace wires a diagram is never required.
Apr 24, 2010 | Kenmore 75101 Wall/Window Air Conditioner
We have a Bosch WTL 6301 , as the heater not working so what I can do , I have test the Heater and its Ok but no electric comes to it
Could be a faulty thermostat/s, or the timer control unit could be faulty.
The power goes to the thermostat/s before going to the heater.
Mar 09, 2010 | Bosch Axxis WTL 6106 Electric Dryer
Found the fuel pump relay switch in my 94 S10 under the dash beneath the radio, but there are two. Are both fuel pump switches or is it the right or left?
Should be the closest one to your right leg. According to all the wiring diagrams I looked at, not knowing what your vin # is, the fuel pump relay is in most diagrams closest to your leg or the farthest left relay.
Aug 26, 2009 | 1994 Chevrolet S-10
Exercise & Fitness Logo
24 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
