Question about Ricoh Aficio GX5050 GelSprinter InkJet
Ricoh aficio 2035e top feeder error j003
How can I repair top feeder error j003 in ricoh aficio 2035e?
blueydfox
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
  • 86 Answers
SOURCE: ricoh aficio 3025 copies out of alignment
Check the paper size dials (green dials) of the paper trays that are set to match the orientation of the paper loaded in the tray.
On the touch panel display, select Auto paper select icon and retry.
If the dials are correct and the problem still there, please then try to print the counter printout from the User tools (yellow) button or send a print from your computer.
If still with the copies being cut off, please check for toner spillage between the toner unit and Photoconductor unit.
Open the front cover, pull out these units and clean toner spill.
Clean also the laser shield glass. There is a small cover below the toner supply unit, unscrew 1 screw. Pull out the small glass very careful and straight ahead, pay attention not to break it.
Retry copying and printing.
Good luck and please rate me, thanks.
Posted on Jan 21, 2009
  • 46 Answers
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Posted on Aug 28, 2009
joel_baleta
  • 155 Answers
SOURCE: What is meant by error code SC 403 of RICHO AFICIO
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
Posted on Jan 24, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: Why does my Ricoh Aficio 2035e copier produce
Make a copy from the glass by laying your original on the glass under the feeder and see if the lines go away. If they do then you need to clean the small strip of glass that is just to the left of the large glass. If you still get the lines then most likely the cause is a bad drum cleaning blade or possibly both the drum blade and the drum itself. If this is the case then you should be able to open the right side door and look closely at the green colored cylinder, which is the drum, and see if you see any wear lines or black lines on the drum surface. If you do then there is your cause. The drum should always be clean and shiny with no toner, lines or wear "grooves" in the surface.
The lines you are experianceing should be caused by one of these 2 problems.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Sep 30, 2010
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
My machine ricoh 2035 sc code 901 how to remove
my dear total counter error you chek total counter meter
Aug 04, 2015 | Ricoh Aficio 2045e 2035e Copier...
I have a ricoh aficio 2035 and there is error code sc 350, what can i do ?
open the right door and you will see a black sensor above the drum unit.
remove the drum unit and clean the sensor in the machine at that position .
rfix the drum unit and power the machine .
please do this carefully as you may damage the drum .
good luck.
May 05, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
I reset my ricoh aficio 2035e photocopier then error sc 322 apear
error code 322 on a Ricoh/Gestener/Nashua/Aficio is usualy related to the laser unit/Polygon mirror motor, can you hear the motor starting up when you swith on the printer?it shoul sound something like an jet engine starting up, if you do not hear it then ask your local technician to replace the polygon mirror motor.
Sep 16, 2013 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Sc 690
GAVD block i2c buss error
Mar 20, 2013 | Ricoh Aficio 2045e 2035e Copier...
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
Ricoh Aficio GX5050 GelSprinter InkJet Logo
93 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
