Question about Samsung Refrigerators
My side by side Samsung refrigerator (freezer only) is leaking freon. How can I find the leak or what would it cost to find and repair the leak?
Model # RM257ABRS/xaa Serial # 869543EP9006132
SOURCE: Sub-Zero 511 Freon Leak
Paul, we have the same problem with a built-in Kitchenaid and the price of replacing the fridge is out of sight for us. Where did you get the equipment to check the freon and replace it?
Posted on Jul 22, 2008
  • 93 Answers
SOURCE: Chemical odor in refrigerator/freezer
put coffeee grains or orange peeles this will take the smell away thanks from gilles
Posted on Mar 15, 2009
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
SOURCE: I have a side by side Maytag Refrigerator model
We had this model as well. It is part of the fridges 'defrost system' that prevents icing up in the freezer. I had replaced the computer chip in mine (at a cost of about 150 bucks), when at one point when it failed, and the freezer starting freezing over, and after it was 'fixed', it started leaking water onto the floor again. After another year, we finally bought another fridge. Solution... buy another fridge
Posted on Jun 06, 2010
SOURCE: Whirpool Imperial Series UltraEase II side by side refrigerator is leaking from underneath the left side.
no ice
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Samsung dryer model DV210AEW/XAA it isn't too now we're restart button is
here is the manual for your model. good luck
http://www.samsung.com/us/support/owners/product/DV210AEW/XAA
Aug 26, 2015 | Samsung Dryers
Why did fridge stop working, then freezer 4 days later?
how it works. 6 month ago another technician came to this service call and found out that system is low on freon. So he charge it up with freon and add leak dye into the system. Leak was really slow, so he could not find at first. Here Im 6 month later, found leak dye with special light (dye leak set (tools) cost about 180$), did not need to order any parts, but replaced copper tube. Customer paid around 600$ for repair total for this repair. Hope That Helps!
Aug 16, 2015 | GE GDS18LBR Bottom Freezer Refrigerator
Stuff in freezer is thawing. Outside edge of freezer and center divider between refrigerator and freezer getting very hot to the touch. This comes and goes.
this refrigerator had slow leak. last time 6 month ago, another tech from our company was there and charged refrigerator with freon and leak dye. now i found leak dye with special light in the drain pan, spayed with soap - bubbles come out. Replaced that drain high side line. Hope that helps.
Feb 09, 2015 | Refrigerators
Why is my Samsung french door/freezer not working
It is very rare to have a freon leak. It is possible but there are there are things that can cause the refrigerator not to get cold. Is the compressor running. Are the fans running. Is the freezer or refrigerator coils blocked with ice. Usually freon is the last place i look.
Jul 23, 2014 | Samsung RF265AA Bottom Freezer French Door...
Unit is not coolingon eitherside freezer and fridge
Do you have power to the unit? Do you hear the fans running? Is the compressor running? If you answered yes to all of these then call for service, you probably have a freon leak. You could have a defrost issue, check the back wall of the freezer and see if it's covered with frost. Your best bet on a Samsung is to call for service and expect about $350 for the repair if it's not a freon leak and about $700 if it is a freon leak
Jul 19, 2013 | Samsung RS2630SH Side by Side Refrigerator
Signal board model PCN5425RX/XAA
sounds like the little pixels have burnt out. also go to the website of the place you got it from and type in the serial number it should come up with the tv you have.
Aug 01, 2012 | Televison & Video
Freon leak in housing? Can it be fixed
replacing leaking evaporator coil in this video on GE side by side
Jul 22, 2012 | GE FUF17SVRWW Upright Freezer
Refrigerators Logo
14 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
