Question about Vehicle Parts & Accessories
Why have i got water coming in to drivers footwell and i think it is coming in from the engine bay
The carpet is soaked every time it rains cant see any water coming in through the door seal, had new gear lever put in last year, should this have a grommet around it
    Master:
  • 710 Answers
It may be the aircondioning drain, or the windshield.
Posted on Aug 31, 2014
Iam getting rain in my 2003 HSE why.
And where exactly is this rain coming from? The sun roof? The door seals? Seeping in down in the footwells (soggy carpet)?
Sometimes "rain" can be mistaken for A/C condensate that is not draining due to a plugged condensate drain. If your A/C is running and it's hot and humid out then you should see some water drips on the ground underneath the front area of the vehicle. Let it sit in one location for a few minutes after you come in from driving it. Let it sit for a few minutes with the engine and A/C running. Move the vehicle and look for the telltale wet spots from the condensate drain. If you don't see a wet spot then chances are the drain is plugged. The condensate will back up and drain inside the car ...typically in the passenger footwell and making the carpet wet.
Jun 24, 2014 | 2004 Land Rover Range Rover
Water in rear passenger footwells
I have had water intermittently in the right rear trunk area (below the battery) every since an rear end accident. The dealer tells me that there is a vent back there that gets clogged up or opened up and lets water get in there. Not sure that I believe that, but that's the best explanation that they could give me.
Mar 31, 2014 | 2005 Toyota Prius
Water on drivers side foor after it rains in my 1995 honda civic ex
Probably leaking around the windshield then running down the pillar garnish and under the edge of the carpet then showing up in the center of the carpet when it accumilates enough to soak up through the carpet.
Mar 09, 2014 | 1995 Honda Civic
Rain water leaking in drivers side vauxhall meriva
if this is a new shape meriva the problem is the wiper scuttle seal leaking water .it drips into the engine bay,onto the heater pipes and tracs into the cabin.Pour water onto the screen and look into the engine bay,just behind the engine and you will see it drip onto the heater pipes where they enter the bulkhead.It then tracs into the cabin and soaks the carpet.The problem is a foam seal on the scuttle panel when it should be a rubber one.One fix is to ensure that the seal where the heater pipes enter via the engine bay is dry and spray it and the pipes with underseal.Vauxhall are aware but dont have a solution?
Jan 02, 2013 | Cars & Trucks
Rear footwell carpeting getting soaked after car wash or heavy rain
check door/ boot seal on side that the carpet is wet .also if your car has a sun roof check the drain chanels.
Nov 30, 2010 | 2002 BMW 5 Series
Water leading into car between the firewall and carpet. Both sides get wet when it rains, water appears to be between the firewall and the firewall carpet as the firewall carpet does not get wet but the...
Your car probably has AC so the box under the hood has a drain for removed moisture and this can often clog with environmental debris; when that happens, the water can't drain any more and may end up inside the car.
Oct 10, 2009 | 1996 Oldsmobile LSS
Water leaking into 2005 Camry 6 cyl under carpet drivers side.
I think that I can help you. It sounds like your drain-tube is plugged up. Get in the passenger side, and pull the carpet back from under the glove box. Look for a black rubber pipe that goes from a black box, and pokes thru the firewall, on the passenger side. Remove the hose from the box, and have a container ready to catch water. If water comes out of the black box, your drain hose is plugged up. Clean out the clog, and you will be golden.
Jul 27, 2009 | 2005 Toyota Corolla
Interior leak - VW 2003, 1.8 20V Turbo
run water over it yourself and have someone look for the leak inside vehicle thats hat i do at the body shop its the quickest and easist but you need a helperthen you ew=will find the problem quick it may be a seal/ Please rate my response thank you very much
Jan 31, 2009 | 2003 Volkswagen Golf
Water in driver's footwell, '94 Isuzu Trooper
it could be youre window seals leaking, on a dry day get someone to run the hose pipe over the car whilst someone sits inside inspecting for a leak
Dec 17, 2008 | 1994 Isuzu Trooper
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
