Question about Grilling
New Char Broil gas grill heating issue
I have a brand new Char Broil Infrared 4 burner gas grill. I used the char broil conversion kit to use natural gas. However, whenever I use this grill it takes really long to heat up (about 20 minutes) and it tops out around 475-500 degrees. Do grills burn cooler using natural gas opposed to LP?
Is there something I can do to correct this issue? I never had this issue on my old barbecue.
  • tedalank Nov 22, 2009
    I bought a new Charbroil Red yesterday and did change out the orifices, etc to use with natural gas. I can not get the hood thrmometer to read over 350-400F....Yes, I undersxtand that the hood is at a lower temp than the grates by perhaps 100F... still, not nearly as hot as claimed. I don't see any answer to the similar post here...SHould it be indicating cooler than with LP? Does it affect the performance? Do I merely have a non-infared for all that $ and work? ....also, the ignitors don't work either...and yes, I tried a new baterry and it is installed + side outward!
    The customer support center didn't have a clue....would you think they would at least know what a typical hood temp should be with this unit on NAt GAs?
    Yes, this is not a soln, but hoping it might get someones notice!
    Problem Solver:
  • 8 Answers
Did the kit come with NG orifices and did you use them.
Posted on Aug 05, 2009
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
The burners will not light. It appears that they are no getting any propane from the tank. Unfortunately, I have missed the manuel and this is a brand new grill. First time trying to use it and have...
The problem is more than likely the OPD Valve in the gas tank. To solve this problem, turn the Tank Valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY,VERY SLOWLY (Slow motion, slow). Once it's fully open, light the burner farthest from the tank first and turn it to it's highest setting. Does the flame height look correct? If so, light the remaining burners following the same procedure. Now, to all the flame heights look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly. If it didn't solve the problem, make sure you have adequate gas in "old propane tank from the other grill."
To further help you, I have included a link to your Owner's Manual that you can download and print for future reference. http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463247310%20english.pdf
In addition, here is a link to Troubleshooting Gas grills
http://www.charbroil.com/Support/Troubleshooting_Level2/4/Gas-Grills.aspx?Model=463247310
I really hope all of this information has helped you solve the problem. Please let me know and Happy Grilling.
May 22, 2011 | Char-Broil Grilling
Ignitor
Check out the product manual, if you need a new one you can download free at Char-Broil.com. Should be a simple fix. Any problems and you can contact the company, they are most helpful!
Jul 02, 2010 | Char-Broil CharBroil 4637318 Grill
Use of Charcoal or Lava Rocks in the Char Broil Patio Caddie?
LP grills are designed to use lava rock ONLY. Charcoal will clog the burners.
May 16, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
Regulator Repeatedly Reduces The Gas Flow
The new regulators will automatically shut down or reduce flow if the it senses that the flow is too high (as in a line leak or break). It can also be folled if you open the valve too quickly. There is a special plastic plug that can reset a tripped valve in the new tanks. (Mosquito Magnet supplies one with their product).
The other thing is that there is a recall going on at Char Broil of defective thermometers that are reading too low.
Sep 28, 2009 | Char-Broil Commercial Stainless Steel...
Char Broil grill w/full tank and cleaned air jets, no heat
try opening the tank really slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 17, 2009 | Uniflame FG2204C Grill
Char-Broil Advantage 463453306
I dunno, I have not done the conversion for this particular barbecue, but the kit is listed in the parts list for that barbecue,
It would be appropriate at this time to print the conversion instruction manual and take it to a local 'guy' a gas fitter.
The instruction .pdf shows them converting 3, 5, 7 burner units with the same kit, and states
  • Insert orifice removal tool provided with kit onto firebox burner openings and unscrew orifices from valves.
    Save removed orifices for later if converting back to LP Tank Gas.
    The valves are designed to work with natural gas once orifices are removed.
    Do not replace any Orifices when using natural gas.
    NOTE: your gas conversion kit comes with replacement orifices for the Rotisserie Burner ONLY, do not use on Tube burner valves.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/assembly%20manual%20-%204584609%20ng%20conversion%20kit.pdf
seems the same 2-burner kit is for all barbecues
I think the person on the phone messed up, but a gas-guy would know for sure
Jul 01, 2008 | Char-Broil Advantage 463453306
All lpg(propane) fueled barbecues can be converted to natural gas some easier than others.
The process requires changing the tiny lpg nozzle with a larger low pressure ng nozzle,
Charbroil web site lists the kit -available parts for the grill http://www.charbroil.com/consumer/product_detail_e.aspx?ProductID=438
the gas conversion kit from half way down the page
http://www.charbroil.com/consumer/product_detail_e.aspx?ProductID=1722
for $69.99
  • SHOULD be done by a licensed person for safety & insurance reasons,
Jun 29, 2008 | Char-Broil Advantage 463453306
Grilling Logo
461 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
