Question about Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive
My usb connector of usb hardisk is conected properly to the inside chip how to open it so that i can fix it where are the screw to open the usb hardisk
    Problem Solver:
  • 6 Answers
No screws just pinch sides and pull apart use a tool if you have to I got mine apart with use my hands and a pin
Posted on Jun 23, 2009
Trying to reboot my PC
There is some posibilities that generate that error, this is some of them :
1. Your Hardisk error, your bootable psrtition is corrupt or something, can be caused by not properly shutdown, repair OS with CD recovery may help you.
2. Your hardisk is fine, but you attached new non bootable hardisk, if yes, you may need to change boot order on bios.
3. You attached USB FLASHDISK, or USB Hardisk, try to remove that and rebot your komputer.
Oct 29, 2017 | Computers & Internet
I have a Belkin 1GB USB data stick. I have damaged the connection. I have been told that it is impossible to repair or retrieve the data. My life is on it! I need the data urgently!!
A: if you want to take a risk, try bending the top of it back to it's normal position.
B: You might want to open it up and check for internal damage. Most flash drives are held together by a screw or can be **** open with a penknife. Bend the plug back to it's normal position, and try putting it back in your computer. If your computer picks it up, copy off all the data, and buy a new flash drive!
If that doesn't work, contact a data recovery specialist in your area, and they will be able to help you! Good Luck!
Aug 07, 2008 | Belkin USB PDA Adapter (F5U109EA) Serial...
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
Why my hardisk drive cant detect in pc,thx for answer.
It could be one of the following
1. Faulty USB port on PC:  Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case senario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Good luck,
Martin.
Jan 01, 2011 | PQI H551 500GB 2.5" USB 2.0 Portable...
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
How to replace ribbon on nokia 6085 my phone works but screen is blank!
Well, you need to remove the hinges that are in the middle where you flip the phone. The correct method would be: 1. Open the top panel (One covering the small blue LCD) 2. Remove the screws connecting the chip. 3. Remove the chip by removing the connector. 4. Open the battery cover. 5. Remove the plastic guard that's above the battery cover - you can do this by hand. 6. Remove the 4 screws here. 7. Remove the back cover and the chip. 8. Remove the connector connecting the chip. 9. Carefully press the hinge on the left side through a small hole in the side with a thin strong device. Now you should see a pin slide out towards the middle of the phone. Hold this pin in place with a screwdriver - if you don't, it'll slide back into place. 10. Pull out the top panel now. 11. You should easily be able to remove the ribbon connector. Work backwards to fix it all back :) Hope you fix it :)
Apr 22, 2010 | Nokia 6085 Cellular Phone
How to fix the usb that is been pushed in?
Be brave, be bold... you only need a Phillips screwdriver to open the side cover (2 screws). Once you have access to the darkside... I meant INSIDE of the PC it is even easier to put in place the USB connectors.
Apr 14, 2009 | Computers & Internet
Son left hard drive on desk no instrucions and i don't know squat
1.turn off your systm.
2. you need to open your pc cover,
3. find the cable connector which fit with your hardisk
4. connect that cable with hardisk
5. connect the power cable with hard disk
6. fix the harddisk to avaiable bay
7. close cover
8. power on
hope it will solve your problem
Oct 16, 2008 | Computers & Internet
When i connect my seagate via usb nothing comes up on my pc, the light comes on on the external h/d but nothing pops up on the pc? help please i need precious photos on it. thanks
have you try connect your pen drive to the same usb port, is it working?
If Pendrive is working but not the Seagate hardisk. Most propably is your USB power is not enough to support the External Seagate hard disk, you need to supply more power to the Seagate hard disk by using USB Y cable(1 end connect to Seagate hardisk where the other end got 2 USB connector to connect to your PC).
Jul 30, 2008 | Computers & Internet
Seagate Free Agent Go Small 12 GB USB External HD ST600121GSA1E1-RK USB 2.0 Hard Drive Logo
100 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
