Question about KitchenAid Dishwashers
Dirty dishes Pump went on this machine about 6 months ago. Since the install of the new pump the dishes do not come clean. Particles finely ground or tomato seeds, sesame seeds etc. get blasted back on the dishes in the final rinse cycle. Repair guy has no clue... could there be a pinched line upon install that won't allow complete drainage, or the wrong pump? Is ther filter screen? I have done the vinegar reoutine plus a purchased cleaner to no avail. The machine is a bout 13 years old. Thank you
  • Cdnmom Nov 04, 2007
    Sorry - Kitchen Aid Superba YKUDA230YW1
  • 87 Answers
SOURCE: Top rack dishes have grainy particles on them after washing and will not come clean.
Run the dishwasher and observe the spray arm,if split it will spray water down: Also check water in tub, is it filling up sufficiently to get near the heater? If it has a upper spray arm does it spray water? If not you may have a clogged upper spray arm.
Posted on Jun 08, 2007
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
Nicesuit
  • 61 Answers
SOURCE: My indesit DI620 isnt rinsing the contents properly
its the same water that rinses both sections just different arms, the one directly under the top basket usually cleans both cutlery and top basket. it could be a posibility that the arm itself is contaminated with waste that is too large to push through the holes and is now breaking up making a mess on teh glasses. (I have seen it before with melon seeds) remove the arm and rinse backward under a tap.
make sure that the salts are topped up as well this is very important if the salts run out you will not regenerate the resin beads which are used for water purification on the last rinse so this could also rinse with dirty water.
Posted on Nov 28, 2008
  • 382 Answers
SOURCE: My dishes come out dirty and glasses are cloundy.
#1 check the upper spinner arm to see if it is clogged with particles if it is, clean the holes outi f they get clogged the arm-sprayer will not clean the upper rack
#2 if it is not clogged got to your local Grc.chain and purchase a bottle of dishwasher cleaner for about 8.00 follow all instructins on bottle make sure water is hot by running hot water tap closest to dishwasher.use it in an empty dishwasher.You will be amazed how clean your dishes will come out after the first wash
Posted on Jan 23, 2010
techbuster
  • 5081 Answers
SOURCE: our ten year old kitchenaid dishwasher doesn't get
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Posted on Aug 29, 2010
Dishwasher not cleaning dishes
DISHWASHER NOT CLEANING WELL??
Here are 5 common reasons why not.
Here are Improper Water Temperature
I can tell you from personal experience that water temperature has a direct impact on how well your family's dishwasher operates. If the water entering your dishwasher is not hot enough, your dishes are likely to come out coated with grease and dish detergent residue. As such, you will want to make sure that the temperature of the water inside your dishwasher is somewhere between the range of 120 degrees Fahrenheit and 140 degrees Fahrenheit. If it's not it could be a faulty heating element.
Dirty Pump
Based on my experience, a dirty dishwasher pump will also cause your dishwasher to produce less than stellar results. Therefore, you may want to consider cleaning your dishwasher's pump every six months. In many instances, it is an easy task to complete. In order to clean your dishwasher's pump, you'll most likely have to remove the dishwasher's spray arms. Once the spray arms are removed, you'll want to clean and inspect the pump's impellers, blades and pump guard. I should also mention that there are appliance companies that sell dishwasher pump repair kits should you notice that a part needs to be replaced. A basic dishwasher pump repair kit will tend to cost you $20 to $60 depending on your dishwasher's unique needs.
Dirty Spray Arm
Dirty spray arms may also be to blame. After all, if the spray arms' holes are clogged, the hot water won't be able to reach the dishes properly. A dishwasher's spray arms are very simple to clean. In order to clean them, you will need an old toothbrush and a bread twist tie that has been stripped of its paper. Use the toothbrush's bristles and the wire from the bread twist tie to unclog all the holes.
Broken Dish Detergent Dispenser
A broken dish detergent dispenser is another likely culprit when it comes to dish cleanliness problems. Sometimes the dish detergent dispenser's door will not open or shut properly, which prevents the dishes from getting nice and soapy. The good news is that most dish detergent dispenser problems may be solved relatively inexpensively. The cost of a replacement dish detergent dispenser will vary based on the make and model of your dishwasher. There are also instructional videos online that will help you with the installation of your dishwasher's new detergent dispenser.
Dirty Filter
A filter has an impact on a dishwasher's effectiveness as well. Hence, you will want to inspect your dishwasher's filter for obstructions. The location and type of filter will vary based on your dishwasher's make and model. I would recommend that you check out your dishwasher's operator's manual. It should contain instructions on how to clean your particular unit's filter as well as where you can order a replacement part if need be.
Dec 16, 2013 | Dishwashers
It is an older model maching and it seems to be clogged and not cleaning the dishes..how do you unclog it
It would be helpful to know exactly what machine you have, but the bottom line is, you need to access the screen at the bottom of the machine, where the water exits into the pump. Many units have a macerator blade in front of the screen that chops up large particles of food so that they will pass through the screen. The blade is attached to the same shaft as the pump, which both supplies the high pressure water to wash dishes and pumps out the dirty water at the end of the cycle, and if there are small hard particles, such as bits of bone, plastic or broken glass in there, they can jam the blade so that the pump does not pump properly. You will need to remove the dish racks whatever covers, etc., are on the bottom inside the machine to get at the screen and/or macerator.
Mar 18, 2011 | Microwave Ovens
Dirty Dishes Electrolux builtin dishwasher
How long ago did you clean the filters?...are they blocked or maybe damaged letting particles through.A cherry pit should not be able to get to the pump.
Jul 20, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
Residue and food particles left on dishes in upper rack.
Check the inlet screen at the bottom of the dishwasher that could impede the flow.
Otherwise the pump may be to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore HE2 Plus Front Load Washer
GE Dishwasher - poor cleaning
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Mar 10, 2017 | Kenmore Dishwashers
Water not draining and not clean
When dirty water is left in the dishwasher the pump assembly is a primary cause. To assure that the dishwasher gets fully repaired and you are going to do the work yourself, I would order and install this part:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-16529000-%3d%3dc261i1065702&PartID=1065702
Also, check that the heating element is working. Many people replace the heating element whenever they replace the pump/ motor.
Good Luck!
Mar 27, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishes have dried on food particles after cleaning
common problem with dishwashers, the filters become blocked/ break down, a cleaning cycle with an approved detergent usually fixes this. if not, the filters my need replacing.
Oct 24, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Washing machine water pump
It is posible that something is blocking the water pump wheel from turning and getting the water out....You have to do a visual check....and listen if the water pump motor is working...hopfuly then you have just to clean the water pump from debris , like lint,hair, or a shirt buton.
Feb 28, 2008 | Washing Machines
Dishwashers Logo
59 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
