Question about Exercise & Fitness
I have the Horizon Elite 507 treadmill. When switched on, the digital display just scrolls through all the displays nonstop. How do I reset?
5 Suggested Answers
  • 14 Answers
SOURCE: I have the horizon elite 507 treadmill, how do I
Is it all the way over to one side? Is the belt damaged on one side? If it is damaged you will never get it to Track correctly.
If it is not damaged, then start the treadmill moving at about 2.5 mph, if the belt is all the way to the right then turn the right rear roller adjustment bolt, clockwise one full turn, and wait. did the belt move over a little? if yes the increase the speed to 5.0 mph and observe.
Make small adjustment from one side only until you get it straight.
Posted on Jul 08, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a Horizon elite 507 treadmill, everything
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem. Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
Posted on May 23, 2010
Testimonial: "Many thanks for prompt response, seems that the treadmill works only when in the upright position and not the horizontal as per normal. Gonna have to learn to run up walls i guess"
  • 14 Answers
SOURCE: The console display on my Horizon Fitness T63
Sounds like there is a stuck button on the console, or possibly a loose ribbon cable inside the upper console maybe?
Posted on Oct 25, 2010
SOURCE: change speedometer readin on elite 507 treadmill from mph to kph
I know this is an old thread, but if you are still trying to change between mph and km, then follow these instructions.
The setting is changed by a switch on the console circuit board. Unplug the power cable. You will need a medium philips screwdriver. The console is fixed to the frame with 4 screws, climb under the console and remove 2 screws from the top and 2 screws from the bottom. Get back up and lift the console up slightly making sure you do not dislodge any cables from either the left or right-hand side of the console. Look under the console from the left-hand side, in the middle of the circuit board you will see a small slide switch (silver casing with black slider), slide it to the other position. You will see next to the switch the letters mph and kpmh. gently reseat the console, put the 4 screws back in, the console should now display the speed in kmph when you plug it back in and turn it on.
All the best
Posted on Feb 24, 2011
Horizon Treadmill Ct5.1 turns on, displays nothing and beeps nonstop
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 26, 2016 | Horizon Exercise & Fitness
Horizon t207
follow this steps and fix it. God bless you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 08, 2013 | Horizon Exercise & Fitness
How to change from km to mph
from below display board, there are small orifice. Use pencil erase point. and clich the smal switch, and ready. However some models you must go to the Menu and make the set up for to change the speed kms vs mps.
God bless you
Jun 07, 2013 | Horizon treadmill Elite T3000
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
The console display on my Horizon Fitness T63 treadmill won't stop scrolling/flashing the programs (P1-P6) and will not start up.
Oct 21, 2010 | Horizon Fitness T90 Treadmill
Lube Belt displays on digital display how to reset or where to lube the belt.
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Jul 28, 2010 | Horizon Exercise & Fitness
Change speedometer readin on elite 507 treadmill from mph to kph
All the best
Jun 12, 2009 | Horizon Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
