Question about Ingenico Inc. i6550 Signature Capture Payment Terminal Network Terminal
How to reset to factory defaults
How do I restore the device back to it's factory defaults?
How to reset clock on 6520 mpbile
Follow the instructions on the screen to set up your phone and prepare it for use.
  1. Find "Reset all" Press the Navigation key. Select Settings. Select Security. ...
  2. Restore factory default settings. Key in the phone lock code (default is 1234) and press the Navigation key. Press the Navigation key to confirm.
Doro 6520 - Restore factory default settings - Device Guides
https://userguide.vodafone.co.nz/doro/6520...os/basic.../restore-factory-default-settings/.
or go to this link might help.
How to reset clock on 6520 mobile Google Search
Oct 28, 2017 | Computers & Internet
Nokia format nokia 5000d
Nokia 5000d hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 3110 Cellular Phone
How do I restore factory defaults?
hi,
If you want to restore the Linksys WRT120N router to default, you should find a reset button at the back. It will require a pin to press it. you have to hold it at lest 5 seconds and it will be resotored to factory default settings.
Thank you for using fixya.
Jun 16, 2011 | Linksys WRT120N Router
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
How do I do a reset
This printer doesn't support a COLD RESET
However it will set customer accessible menu settings back to factory default settings
Restoring the factory-set defaults returns all of the settings to the factory defaults.
To restore the factory-set defaults
1. Use the (Left arrow) or the (Right arrow) button to select Service, and then press
(Select).
2. Use the (Left arrow) or the (Right arrow) button to select Restore defaults, and then
press (Select).
The device automatically restarts.
Feb 09, 2011 | HP LaserJet 2605dn Printer
How to reset zebra p4t ribbon cartridge?
Below are the command sequences that can be applied to default the parameters referenced above:
Examples:
! U1 do "device.restore_defaults" "bluetooth"
! U1 do "device.restore_defaults" "ip"
! U1 do "device.restore_defaults" "wlan"
! U1 do "device.restore_defaults" "power"
! U1 do "device.restore_defaults" "display"
The zpl parameters can be restored to their factory defaults on the P4T series, RW series and QLPlus series by deleting the ZPL_CFG.CFG file. This binary file contains the zpl settings and will be recreated automatically when restarting the printer. The newly created file will contain the binary equivelant of the factory zpl default settings.
The ZQ500, QLn series and the iMZ allows the ^JUF and ^JUN command to be sent to restore parameters to their factory default condition.
Example: ^XA^JUF^XZ^XA^JUN^XZ^XA^JUS^XZ
Please note that the iMZ uses line print mode by default. The command ! U1 setvar "device.languages" command may need to be adjusted to se the iMZ back to ZPL if necessary.
! U1 setvar "device.languages" "zpl"
Zebra Technologies Restoring Factory default settings with Mobile Printers CCTV Networking Technical Support
Feb 04, 2011 | Zebra 05555bk110d 4.33 X98' Tt Wax/resin...
Its because it got reset accidently and then how would i restore it back again. or can it still be restored back??
Sorry you will have to set it up again
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
hope this helps
Dec 05, 2010 | NetGear WG602 802.11g/b Wireless Access...
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
May 12, 2010 | Intermec CK31 Portable Terminal
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
Ingenico Inc. i6550 Signature Capture Payment Terminal  Network Terminal Logo
Top Ingenico Computers & Internet Experts
David Payne
David Payne
richie46
Are you an Ingenico Computer and Internet Expert? Answer questions, earn points and help others
