Question about Waterway Impeller Pump 2HP SD WW
Pool pump makes a loud noise
It is making a very loud noise when it runs. still filters but the noise is disturbing the neighbor hood. Pool is only 2 years old
    Top Expert:
  • Waterway Master
  • 5,045 Answers
Bad bearings change pump and motor
Posted on May 01, 2016
john224
  • 1378 Answers
SOURCE: 1.5 hp waterway champion pool pump issue
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
Posted on Jul 28, 2009
  • 11800 Answers
SOURCE: I have a Waterway SVL56
That means that the connection between the motor and the actual centrifugal pump is broken. This is terminal: replacing the broken part will cost you more than the price for a brand new pump. Just cut your losses and replace it.
Posted on Dec 18, 2010
jharwell668
  • 640 Answers
SOURCE: I have a Waterway 48-Frame 2HP 115v pool pump for
Check to see that the pool pumps mounting is secure. Loose mounting could cause the motor to run loudly. It could be bearings rubbing or a bent shaft. If it is new, this should not have happened. If you check the mounting and feel that it is secure, I would return the pump to an authorized Waterway service agent and let them look to see if the bearings or shaft are damaged. I would do this quickly while you can still return the pump if its defective.
Posted on Apr 26, 2011
  • 54 Answers
SOURCE: I GOT A 2 SPEED
Sounds like you don't have the pump lid "0" ring seated properly under the lid, or there is dirt or leaves on the "0" ring. This has to seal perfectly or the pump will not pump much if any water.
Posted on Sep 03, 2011
badfish6686
  • 563 Answers
SOURCE: waterway pool pump is humming but fan is not turning
Shorted motor windings, can you move the turbine when turned on or does it feel like it is being held in place. WARNING!!! do not try with your hand, use a tool. Possible capacitor, but I would suspect motor to turn slowly.
Posted on Apr 10, 2013
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Filter working but making noise
This is an inexpensive product put out by China Manufacturing. So sorry to say, but you probably knew this as well, it is not of high quality and was not made to last. It actually is considered a Toy.
It sounds like you need to either live with the noise or replace the pump. I would recommend that if you can find it in the budget, upgrade to a real Pool Pump. Ask your local service provider or retail pool supply store about such an upgrade. But your pump is failing.
Good Luck.
Apr 29, 2015 | Intex Krystal Clear Model 635 Pool Filter...
When I turn on filter the pump makes a loud noise, then kicks on but runs loud.
these are known to have rear end bell issues , the motor will need service by your local pool pump motor repair guy. cost about 75.00 .. if you keep running it it will destroy the motor and a new motor will be your only choice .Leave feedback for your favorite fixya guy.. that would be me the pool pump motor repair guy in longwood Florida.. don't forget to prime your pump after a repair !!
Mar 26, 2012 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Pool pump is making a loud screaming noise. It is pumping ok though.
Sounds like the bearings are worn. If they are you will soon need a new pump.
Jun 08, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
The pump is making a loud noise.
Did you prime the pump? Is it pumping ok, or is it pumping dry? When does it make the noise?.. more info please...
Problems with Intex Krystal Clear Model 635 Pool Filter Pump 1500
No, the pump should not be noisy. It sounds like you have picked up a foreign object in the pump housing. you may have to pull the face off to determine. OR the pump/motor is indeed defective and should be returned.
Mar 15, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Pool filter making a loud noise
The sound you are hearing is most likely rust forming on the inside of the motor. It tends to happen when a pump seal starts to fail. Water travels up the spining shaft from behind the impeller into the motor. The high pitch is a direct result.
Solution. Replace the pump seal, and find a motor repair shop/ Pool pump repair shop to take a look at the motor. Have them check the brushes and bearings. Once clean of rust the motor should be quiet once again.
Jan 25, 2009 | Harmsco Pool and Spa Cartridge for Filter...
Waterway Impeller Pump 2HP SD WW Logo
100 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
