Question about HP LaserJet 9050 Printer
Hp p1606dn printer paper jam under the toner
A small piece of paper is stuck under where the toner sits. i can barely see it but can't remove it.
    Scholar:
  • 51 Answers
Have you tried to lift the green handle from right of the metal plate that sits under cartridge? If you cand see the piece of paper, maybe you can grab it with a tweezers. Otherways you will need to remove the front dor assembly and then the feed/transport section. With some technical skills, you will succed to put it back, but don't start if is the first time you disassemble an printer.
Posted on Jun 03, 2014
  • 624 Answers
SOURCE: Hp Color LaserJet 3500 Paper Jam
The only way to find paper remnants is to unplug the printer and inspect the paper path. It also helps to have a good focusing flashlight, skinny needle nose pliers, a can of compressed air (used sparingly) and a long thin probe. Your specific printer should be giving you jam messages with a location code as well. I?ve attached a link to an HP page containing a diagram of the 3500 paper path and the error code jam locations: http://h41206.www4.hp.com/webapps/IV3/node.iv?locale=en_us&prodSeriesId=315862&node=prodITRC%2FNL_HW_IPG_plakCLJ3500_EN_01_E%2FN1%7C6%7C9&prodTypeId=18972&serverId=1#src I solved this problem in my shops years ago by not letting anyone else clear jams OR insisting that any paper removed as a result of a jam is given to me. If any corners or pieces are missing I know what to look for and approximately where. Good hunting and please don?t forget to rate this post.
Posted on Mar 21, 2007
SOURCE: Hp C5280 Paper Jam error - no paper + component fell apart
How do I clear a paper jam?
Posted on Sep 15, 2008
BurntLime
  • 8 Answers
SOURCE: Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
BurntLime
Posted on Jan 05, 2009
FixinFax
  • 3085 Answers
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
SOURCE: paper jam
There's a trap door in back, remove it and easily access the paper jam- credit for this answer goes to my very wise husband.
Posted on Apr 09, 2010
I have a paper jam under the toner. Paper is stuck in the roller behind the toner. How do I get it out?
Yikes....Been there done that. If all fails, you will have to remove the entire front tray 1 assembly to get to the small pieces of paper. It is not real difficult but requires some time and attention to detail.
Mar 26, 2013 | HP LaserJet 4350dtn Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
My hp photosmart 8250 keep showing paper jam but there's no paper jam anywhere. How can I get it to function properly?
Make sure there is no paper stuck inside in the paper. may be there is small piece of paper stuck inside
Just unplug the power and open the cover and remove the toner or cartridges from the printer and manually try to roll the roller and remove the paper.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | HP Hewlett Packard Photosmart 8250 InkJet...
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
Feb 09, 2010 | HP LaserJet 2420 Printer
Paper jam
HP Officejet 4315 paper jam. 01. Please remove the toner / catridge from the printer. 02. Carefully remove the jammed paper if any. 03. Please ensure that no small piece of paper got stuck in the roller. 04. Switch off the Desktop / Laptop and printer and reboot the systems once again. 05. See still the paperjam message / lights are blinking. If still the problem is there, please call the HP Printer Service Engineer to set right this problem. Do the following also to find out the solution. Call HP Customer Care Toll fee number, and you will find the solution. I f still the problem exists they will make a report and someone will contact you soon. They are good in after sales you can trust me on this. If the printer is under warranty, they will replace with a new Printer. Have a Nice day.
Jul 16, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Cannot clear paper jam on L7580.
give this a try
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp d1320
go over these steps
alternative :
Sep 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP OJ 6310 All in One Paper Jam
check for a small piece logged inside, remove the toner cart and check that, take paper out and check under that
Jan 10, 2008 | HP Officejet 6310 All-In-One InkJet...
Paper jam
If you have pulled out paper that was stuck before you may have flipped a sensor flag out of position. I have found in the past small pieces of paper left under the plate at the very bottom of the toner catridges where the paper comes in.
Jan 04, 2008 | HP Color Laserjet 3550 Printer
Paper jams
Hi conniebrown you may be using a card that is too heavy for the machine check the specifications that you card is within the recommended guidelines of not use a lower weight card. Also make sure that you are putting the card through the tray 1 unit and that on the driver properties you have selected card stock. Try this I hope it works for you.
Hi Guest you may have a piece of paper stuck under that registration unit open front cover remove the transfer unit and also remove the toner cartridges. Once this is done at the bottom you will see where the paper guides through (Black unit with green piece in the middle) close the front door half way then you will be able to lift that unit up and check underneath it. There is normally a small piece of paper there causing your jam.
Hope this helps
Thanks J
Nov 05, 2007 | HP Color LaserJet 3500 Printer
HP LaserJet 9050 Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
