Question about Honeywell TH9421C1004 VisionPRO IAQ Total Home Comfort System
Stuck on cool setting and wont respond to my touch
Stuck on cool setting wont respond to my touch to change
Source button does not work The hisense Tv cannot respond to change to hdmi and is stuck on monotv
new batteries. But that won't solve the problem if the universal remote apply other code. when the original remote is applied, you touch the tv icon to be sure you are using the correct parameters. When it still won't solve the problem you go to the ir circuit on the set. the reason may be because of the accumulation of the dust and dirt on the buttons.
Apr 30, 2016 | Hisense Televison & Video
How to fix Syncmaster 2494hs touch menu problem?
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
May 11, 2014 | Samsung Computers & Internet
Touch screen not working
i have same problem the cable to cn8 is broken on mine. maybe yours is unplugged but so you know it's $600 for servvrvice man and $ about $300 for the part so far I have NOT found a way around it BUT I am NOT done yet. Joe Comer. You can contact me directly ayt joecomer39@gmail.com
Mar 20, 2013 | GE Profile Harmony DPGT750EC Electric...
Cool option not working
Membrane is not responding to your commands; a very delicate operation to repair. Since"cool" lite is not responding that is the first thing, regardless of where other settings are at. Change other settings one at a time and see if the cool button will respond.................bob
Jan 05, 2013 | Heating & Cooling
My htc inspire ,the touch turns on but wont respond to touch
try to unplug lcd and touch from board and plug again, maybe this solve the problem, if persist you need to change it buying new one. (to dissambl and ressembly see videos on you tube), i think this will help you to solve the problem, Don't forget rate my answer.
Jun 29, 2012 | HTC Inspire Cell Phone
My 3g iPhone is has clear all recents / Cancel stuck on the screen and wont respond. it will not respond to touch, I tried to turn it off but I cant slide to turn it off. when I touch clear all or cancel...
try a soft reset hold power button and middle button at the same time until you see the apple logo...if that doesn't work you could always plug it into itunes and click restore factory settings
May 04, 2011 | Cell Phones
Getting error code F0 during oven cool down. During F0 keypad does not respond to clear error, however after waiting several hours error can be cleared. Next use is fine but error reoccurs during cool...
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 31, 2011 | GE Profile JGS968 Gas Kitchen Range
I had a cracked screen but everything was fine i had no problems what so ever with the itouch i went to take it in and got a brand new screen but when i try to touch the screen it wont respond to me it...
That means you have a bad digitizer. When the screen was changed so was your digitizer which is a part of the touchscreen on the back. When your glass was changed so was the digitizer which is attached to it. You a new touchscreen...
Oct 16, 2010 | Apple iPod touch
Screen won't respond to touch
Put mailing tape across the screen then lift it off. I think that the sceens get stuck together and when you take the tape off it "unsticks them".
May 27, 2009 | LG AX830 Glimmer Cell Phone Car Charger
Touch screen wont respond
double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
Jan 29, 2009 | Nintendo DS Lite Console
Honeywell TH9421C1004 VisionPRO IAQ Total Home Comfort System Logo
170 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
