Question about Datacard Group SP75 Color Card Printer
Printer wont print full bleed - Datacard Group SP75 Color Card Printer
7500 dt to print full-bleed
This printer is not capable of printing full bleed. You will have to print on oversized paper and trim it to get dull bleed.
Jan 10, 2014 | Xerox Phaser 7750 Laser Printer
How can I print full bleed on konica Minolta C451
Hi, unfortunatley you cannot print full bleed on any printer that uses toner. The way to do it is to print them on A4 Wide or A3 Wide paper and them trim them like you mentioned.
Sep 13, 2012 | Konica Minolta Bizhub C451...
How do I eliminate the margin so it prints out to the edge? I have done a search for a full bleed. No reference.
Unfortunately, Xerox solid ink printers don't print full bleed. It is a shame because in theory, the machine is capable of it but it would require a firmware/driver programming/design update which Xerox are unlikely to do.
Jan 19, 2011 | Xerox Phaser 8860MFP Printer
Office printing 8.5x11 full bleed possible?
try deskjet c4480 or hp color laserjet p1515
Feb 01, 2010 | Office Equipment & Supplies
Printers with full bleed capability?
NO!
Just like on a printing press that toner is being imaged somewhere when it runs out of the sheet. The toner is going on the imaging belt/fuser. Over time it will build up and ruin the device. On a press they can stop and wash the imaging blankets. Full bleed is achieved by running on oversized stock and trimming off excess afterwards. That is how the "Pros" do it.
Apr 13, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I can't print full bleed from CS3 to a Phaser 7750DN
You didn't mention paper size, so my apologies if you are using a sheet that will accommodate bleeds and just didn't mention it. This is the simple answer.
If you printing on 8.5 x 11 paper, you can't get a full bleed. You'll need to print on a larger paper size, like tabloid, and trim your 8.5 x 11 size out of that. There are no printers, even commercial offset printers, that can bleed an 8.5 x 11 design on an 8.5 x 11 sheet. There must be trim in order to get the bleed. it 'bleeds' off the edges of the design.
Nov 11, 2008 | Xerox Phaser 7750DN Laser Printer
Full bleed printing
feed the stock thru the Multi prupose tray. Set a custom size in the PDD to 5 mm larger diamension for W and H. this fools the machine to thing larger stock is being printed. feed your original stock. do not scale to fit....and presto, you can print to full bleed...
Sep 10, 2008 | Xante Ilumina Digital Color Press Printer
I want to change my printer settings to print on the full page, not have these 5mm margins all the way round. can someone help? I have a Kyocera FSC5015N
It sounds like you want to print what is called "full bleed" which means that you print from one edge of the paper to the other edge with no margin. Unfortunately your printer can't do this. It is a limitation of the design of the printer that is common to most laser printers. You have two options, either print with the 5mm margin all the way around and trim the paper or get a printer that has a "full bleed" option.
Henry
Apr 22, 2008 | Office Equipment & Supplies
Full bleed
sure, first you need to use 12x18 paper in the bypass tray. The using your application select to print 11x17. you then cut the paper to 11x17, thats the only way to print full bleed on this system.
http://www.websitetoolbox.com/mb/copierquestions
Jan 07, 2008 | Ricoh Aficio CL7000 Laser Printer
Datacard Group SP75 Color Card Printer Logo
19 people viewed this question
Top Datacard Group Office Equipment & Supplies Experts
Jaime Hernandez
Are you a Datacard Group Office Equipment and Supply Expert? Answer questions, earn points and help others
