Question about Car Audio & Video
Delco manuals for steam clean Vortex 53G - Car Audio & Video
I forgot to tell you what kind of phone it is, free government phone Vortex Image and Blue Jay Wireless is mycarrier
You can download the manual for the LG Vortex Image phone from this link: LG Vortex Manual User Guide . The manual should have instructions on how to increase or lower the ringer volume.
Jul 31, 2017 | Cell Phones
Manual with diagram for vortex Hunter 45-65 lb compound bow
You can download an electronic manual from Barnett Vortex Hunter Compound manual from the crossbow company.
Here is the address:http://www.barnettcrossbows.com/vortex-hunter
Sep 18, 2015 | Archery
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Shark 2-in-1 Vac Then Steam
Steam frame and pad
must be attached to the cleaning unit
in order to use the steam function
manual > http://www.sharkclean.com/manual/MV2010_11_IB_ENG_110103.pdf
Apr 15, 2013 | Shark MV2010 Vac-Then-Steam 2-in-1 Vacuum...
How do I clean the vortex on a dyson vaccumn
here is a video how to take apart the vortex , you can clean it in worm soupy water BUT make sure it's absolutely dry before you put it back to use.
Jan 13, 2013 | Vacuums
I need a owner's manual for black & decker vortex vaccum
Model number would be great!
Try here:----> http://lawnandgarden.manualsonline.com/manuals/mfg/black_decker/black_decker_blower_product_list.html
Dec 03, 2012 | HP Pavilion dv6000z Notebook
How to change spark plugs in in-line six vortex engine.
Take all the plastic off the top, very simple. Take the two bolts off of each coil, then lift it up and out. There you can access each sparkplug, the last one near the firewall is tricky due to clearance. Very easy, shouldn't take more than 45 minutes. On a side note, buy A/C Delco brand plugs, our TB's love these better than aftermarkets.
Nov 15, 2010 | 2004 Chevrolet TrailBlazer
I have a Sears Craftsman Pressure Washer Model No. 580.752010 Soap will not draw from the throut the plastic tube and mix with the sprayed water. Yes I am using the proper nosel and the tube in not...
A brief reminder of how the detergent is mixed may shed some light. There is a vortex with a small feed pipe. The vortex is fed with the water flow and causes a small vacuum in the feed pipe within the Y piece vortex sucking up a measured amount of detergent.
If there is a blockage in the vortex, it will not work.
Check the small detergent feed pipe is clear through the vortex.
Oct 07, 2017 | Craftsman Garden
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
