Question about Sharp EL-1197PII Calculator
How to set for 1.00 dollar - Sharp EL-1197PII Calculator
I signed up for the unlimited plan for 45 a month with unlimited minutes text messages and mobile web access and today was my last day so I called and now I'm on 1,00 mins for 30. I do not want that...
Thanks for sharing your thoughts with us, but when you really want to change your plan, you should contact your provider not Fixya. We only try to answer (most) technical questions.
Look on top of the page what URL, before you press post or answer.
Feb 17, 2015 | Cell Phones
Paypal 4029357733 charge me 1,00$ at two differents times for nothing what's that
log into your paypal acc. you will see all of your current transactions also a view all of my transactions shortcut bar if its not located in your most current transaction list click on the view all of my transactions shortcut
you have to select dates ranging from the current to a specific date
open up a dispute in resolution tab you will have to find this transaction and copy the details down (date/item no/etc...(write them down) make a list of problems you have with the seller to make a claim
Then open a dispute with the seller or you can contact the seller and tell them of them problem to try and resolve the matter without involving paypal remember there is a time limit on days before you will not be able to make a claim.
I think its 35 days.
Nov 13, 2013 | Computers & Internet
How much is it worth
There is a Saying... "WHAT THE MARKET WILL BEAR"
So to me, NOTHING...
To the woman down the street... $1,00
To the woman on the Cover $0.10 (she has Hundreds in the Case)
To the Woman of Iran PRICELESS
Apr 11, 2013 | Crafts & Hobbies
THE INSTALL DISK WON'T WORK MY COMPUTER IS A WINDOWS XP VERSION 2002 SERVICE PACK 3 AMD ATHLON (TM) 64 PROCESSOR 300+ 1.81 GHz 1,00 GB OF RAM
If you want your installation disk for formatting your system, you can go for any other XP or Vista or Se7en OS Disk to format your computer other than your old XP disk. It will not cause any problem.
Dec 12, 2010 | Computers & Internet
Lost instructions. How do you change value of tax
The c1, c2, & c3 are for exchange rates. To set the c2 exchange rate press AC. Press the MODE M/EX button till EXCH appears in the display. Press and hold the SET/% button for a few seconds until SET EXCH appears in the screen. Press c2, C2 SET EXCH RATE should be displayed. Enter the desired echange rate. For instance, today, Thai Baht is 32.8677. Once you enter your desired exchange rate, press the SET/% button.
To convert 100 dollars using the exchange rate you set on c2, make sure that EXCH is in the display by toggling the MODE M/EX button. Press AC, enter 100, press c1 then c2. Using 32.8677 as the exchange rate 100 dollars would be 3286.77 THB.
To convert 100 THB to dollars you would enter 100, then press c2 and then c1 yeilding 3.04 dollars.
You can also program a different exchange rate into the C3 button. To convert to that currency, you press c1 then c3. To convert from that currency, you press c3 then c1.
Hope that helps
Dec 23, 2009 | Casio MS-80TV Scientific Calculator
Do I need to secure the tubs inside Kenmore Elite Washer & Dryer?
Not the dryer but you do for the washer ... there is bolts that go in the back to hold the tub ... the bolts came with the washer went it was new... you may be able to get a set from sears...
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
How do you use the Exch rate mode? I think I know
From CASIO FAQ:
How do change the currency rate?
When you press the [M/EX] key, it toggles between conversion mode and memory mode. You will see "EXCH" on the display when in conversion mode.
C1, C2, and C3 are three conversion rates. C1 is your home country currency, and so it is always set to 1. C2 and C3 are rates for two other countries, which you can change.
For example, if you want to set a conversion rate of $1 to 0.95 euros, here is what you would do (using C1 for US dollars and C2 for euros):
1. Press [AC]
2. Hold [SET/%] for about two seconds until "SET" appears
3. Press [C2] to select currency 2
4. Input the conversion rate (0.95) and then press [SET/%] to store it in memory
You can check the currently set rate at any time by pressing [AC] and then [C2].
How do I perform a currency conversion?
If you want to convert 100 euros to US dollars, you would do the following (assuming you are using C1 for US dollars and C2 for euros):
1. Press [AC]
2. Enter 100 and then press [C2]
3. Press [C1] to convert to dollars
4. To convert back to euros again, press [C2]
You can also perform a currency conversion within a calculation. How much in US dollars would five items selling at 100 euros cost?
1. Press [AC]
2. Enter 5 [×] 100 and then press [C2]
3. Press [C1] [=]
Jun 22, 2009 | Casio MS-80TE Calculator
PC Battery voor een Dell 4600
When I boot I get an error message - and I think the battery is to be replaced, what and how should I do?
Thanks in advance for the answer! 1. Turn the computer off. 2. Disconnect the power-cable. 3. Remove the side-panel. 4. Look on the motherboard for a silver-coloured circular piece, about 2 cm. in diameter. 5. Read the lettering on the top of the piece. 6. VERY CAREFULLY remove the piece, by lifting from one edge. 7. Take it to a computer-store, and buy a replacement. 8. Check the lettering on the top of the new piece. 9. Insert the new piece, with the lettering on the new piece matching the lettering in #5, above. 10. Replace the side-panel. 11. Reconnect the power-cable. 12. Start your computer. 13. Immediately, press DEL to enter BIOS-setup. Set the date & time. 14. Save/Exit from BIOS-setup. 15. Reboot.
Apr 05, 2009 | Dell Dimension 4600 PC Desktop
I have a 2001 Jeep Grand Cherokee. The car not starting is a random problem. When I turn the key on the lights go on but nothing happens as far as starting. I do not hear any sound at all. After $1,00...
hmm..I am not a mechanic by any means but check out the answer to my problem, maybe it can help in some way. Best of luck to you!
http://www.fixya.com/cars/t951969-starting_problem_key_lock_cylinder
Aug 07, 2008 | 2002 Jeep Grand Cherokee
Samsung SHW08A DVD±RW doesn't burn dvd+r
Please let me know your Operating system and the program you are using to burn the dvd, as well as the word-for-word message you recieve, and I will get back to you right away.
May 20, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
Sharp EL-1197PII Calculator Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
