Question about Saeco Magic Comfort Plus Espresso Machine
When you press the coffee bean button nothing happens
SOURCE: Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Posted on Aug 08, 2007
espressodoc
  • 29 Answers
SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Posted on Aug 15, 2007
  • 3 Answers
SOURCE: add beans??
I had this same problem with my Saeco Magic Plus and found that cleaning the burr grinder fixed the problem. Here's a link showing how that is done:
http://www.cerinicoffee.com/Saeco_technical_documents.asp
Good Luck!
Posted on Mar 07, 2009
mohammed387
  • 1952 Answers
SOURCE: Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Posted on Aug 02, 2009
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
Posted on Jan 25, 2010
Delonghi Perfecta milk frother not heating.
My friend your problem is that the frother heat is foulty
Mar 18, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
! light flashing... machine won't brew coffee - when i press the button to make espresso nothing happens.. I've tried all the troubleshooting options - nothing works.
The machine is sensing one of the following is not properly fitted in.
Check bean lid, brewing unit is properly latch in, dreg drawer and tray is in, and water tank. And make sure the knob is in off position. If all those are properly in ..the green light will start flashing and warming up. When it reaches the working temperature it will start rinsing and it's ready to use.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
No coffee coming out of front taps
The brewhead is blocked the machine will have to be stripped and cleaned and the o rings replaced.
Mar 13, 2009 | Krups Orchestro 889 Espresso Machine
Add beans??
Good Luck!
Mar 07, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Jan 17, 2009 | Krups Burr Coffee Grinder
Grinder runs with NO beans inside
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
Jul 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Saeco Magic Comfort Plus Espresso Machine Logo
35 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
