Question about AKG Perception 120 Microphone
I recently bought the AKG Perception 120 and have a macbook pro. I also bought a XLR to usb cord to record it in Garageband... But there is no sign of any sound going through the microphone. Please he
I just would love to know what else I need to record this. Normal microphones work fine with the cord... Thank you in advance.
arthurroger
  • 170 Answers
SOURCE: AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Posted on Dec 03, 2008
  • 4234 Answers
SOURCE: C 518 ML Isnt Working
Make sure that you are supplying phantom power. This mic requires it. Without phantom power, the mic will appear to be dead.
Let me know if that resolves the problem.
Dan
Posted on Mar 20, 2009
Cableg Eye
  • 22 Answers
SOURCE: AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Posted on Oct 12, 2009
  • 12 Answers
SOURCE: my akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Posted on Mar 21, 2010
  • 5603 Answers
SOURCE: AKG perception 200 microphone won't
You cannot use the AKG 200 unless you use a preamp that will supply the +48 volt Phantom power required by this and most condenser microphones. The Zoom has condenser mics itself, but does NOT source the Phantom power for external use, and the internal voltage it uses on its own condenser type mics is much lower that that required by the AKG 200.
Posted on Jul 17, 2011
I have recently bought an AKG Perception 120 microphone and plan on recording through GarageBand on my Macbook Pro, but no sound is coming through. please help!
You say you have a XLR to USB adapter....so the version of the 120 you have is the regular XLR version, right? Well if it is, it needs what's called "phantom power" to work. It looks like they have a straight USB version of this mic, and that's what you should have gotten if you didn't want to use anything else. If you still want to use this mic as is, I would recommend a Focusrite Scarlett 2i2. I have one and it's great. I do have a pc though and I'm not sure about Mac. But it's a usb powered preamp that gives you two mic pre's along with headphone amp, and a volume control for your speakers and has phantom power built in. Great unit and around $120. NFI.
May 14, 2014 | AKG Perception 120 Microphone
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
I get a quiet signal when using the mic.
You should use the mic input of your computer.
If it's not there, use a microphone pre-amplifier.
Regards,
Gerard
Feb 17, 2010 | Shure SM57-LC Professional Microphone
My akg perception 200 is not responding
Jan 11, 2010 | AKG Perception 200 Microphone
Crackling noise and low volume
If the mic is a condensor you would need to have phantom power, or it will not work. Use a small mixer or externat power supply. We here at Pro Line Music Have small mixers that have phantom power. 215-736-8055
Dec 26, 2009 | AKG Perception 120 Microphone
AKG Perception 120 Microphone Logo
60 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
