Question about Canon ImageClass D880 Copier
The machine says it has a paper jam. We've been through all theprocedures for removing the paper but we think some of the sheet is stuck up inside the machine where we can't get to. How can we take enough of the machune apart to get to the inside of it to remove whatever has ripped off.
5 Suggested Answers
SOURCE: Canon MP830 paper jam
Your "Best Solution" posted 10/01/07 needs just a little bit more. I followed the directions and saw the jammed paper but couldn't get hold of it. I then called Canon support and they told me that the green plastic can be pulled up and then the paper under it is accessible. I pulled up the green plastic and was able to grab the jammed paper and pull it out. He also told me that the solution could be found in the Canon knowledgebase with a color picture as well.
Posted on Feb 04, 2008
SOURCE: paper jam
We had this same problem. You need the back cardboard section of a legal pad. Take out the cartridge and slide the back of the cardboard slowly into the rollers, pushing it out the end where the paper comes out. This helps push the paper jam out. You may have to do this several times slowly to get the jammed paper out. But it worked for us!
Posted on May 21, 2008
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 117 Answers
SOURCE: I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Posted on Oct 09, 2009
HOW DO I RELEASE THE JAMMED PAPER PAPER JAM E
destroy the paper that is jamming it then it should work again.
May 27, 2014 | Epson Aculaser C1100 Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    I have a Canon Pixma 170 printer. I'm getting an error message of a paper jam and there is no paper in the printer. The cartridge cable is stuck on the right of the printer and is not sliding back to the...
    You may have a piece of paper left inside. If the paper tears and a piece remains inside the machine, open the
    Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the
    Scanning Unit, turn the machine OFF and turn it back ON.
    If you tried to print Credit Card-sized paper in the landscape orientation you can get <PAPER JAMMED> or <E,3> displayed on the LCD/LED, remove the
    paper following the procedure below.
    1. Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
    Do not load it in the landscape orientation.
    2. Press [ON/OFF] on the machine to turn OFF the power.
    3. Press [ON/OFF] again on the machine to turn ON the power.
    The paper is fed and the jammed paper is ejected accordingly.
    If you cannot remove the jammed paper or the error still persists, contact a Canon service representative.
    Nov 17, 2010 | Canon Office Equipment & Supplies
    I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    HP j5780 printer sends "paper jam" message AFTER it prints one page. there is no apparent jam in all the places I have looked. I am in need of a repair manual (not an owners manual).
    If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
    Follow the steps for fix HP Printer Carriage Jam
    Turn off the printer and open it to see where the paper is stuck.
    Manually move the carriage toward the opposite side.
    Check the paper path and remove any piece of paper or any other object that is stuck in the path.
    Reconnect the power cord and turn on the printer.
    http://www.fixya.com/support/t6088190-hp_7400_displays
    May 12, 2010 | Office Equipment & Supplies
    Paper jammed
    Paper Jams
    Cause 1 : Paper jams in the paper output slot/Auto Sheet Feeder.
    Action : Remove the paper according to the following procedure.
    a) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
    * If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn OFF and turn it back ON.
    * If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will be ejected automatically.
    b) Reload the paper into the machine and press [OK].
    * If you have turned OFF the machine in step a), you will need to retry printing, because this operation cancels any print jobs in progress.
    If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
    Cause 2 : Landscape Credit Card-size Paper Jams inside the Machine.
    Action : You cannot load Credit Card-size paper in the landscape orientation.
    If <PAPER JAMMED> or <E3> is displayed on the LCD/LED, remove the paper following the procedure below:
    a) Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
    b) Press [ON/OFF] on the machine to turn OFF the power.
    c) Press [ON/OFF] again on the machine to turn ON the power.
    Hope this helps
    Please rate my response.
    Thanks
    Have a good day.
    Dec 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Paper jammed
    found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
    Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Paper jam!!
    Please perform the below steps.
    1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
    2.
    Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
    3.
    Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
    4.
    Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
    5.
    Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
    put the cables back and switch on
    Aug 25, 2008 | Brother HL-2070N Laser Printer
    LCD Error message: Paper output slot. Thye paper is jammed. clear the paper and press OK.
    A jam sensor may be stuck or have something stuck on it, causing the machine to think it is jammed. These sensors are normally located where the paper feeds into the printer, and where the paper exits the printer. Try forcing a sheet of paper through the machine in the direction paper normally. feeds. This may free up the jam sensors.
    Jul 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Problem
    Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same.
    To fix the paper Jam errors please try the following steps:
    1. Confirm that no foreign materials are inside the machine.
    2. Confirm that usable paper is set.
    3. Confirm that the paper is set properly.
    4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
    5. Disconnect the printer power cord as well as the printer cable form the printer.
    6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
    Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
    7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
    Regards
    Malik Khan
    Jan 26, 2008 | Canon PIXMA MP160 All-In-One Printer
    Canon ImageClass D880 Copier Logo
    21 people viewed this question
    old marine
    old marine
