Question about Intertherm Heating & Cooling
Need blower motor 901743 - Intertherm Heating & Cooling
    Sergeant:
    Champion:
  • 234 Answers
Check with W.W.GRAINGER or a furnace HVAC dealer.
Posted on Nov 26, 2014
My blow motor for inside the car sometimes comes on and off in my 2003 Chrysler sebring sedan when it wants to
Any motor that uses brushes, sometimes you can peck on it, it may start running, or you might hit a bump and the blower motor takes off. If so, that is a sign of bad brushes and the blower motor needs to be replaced.
Also when problem is ongoing, check the blower motor wiring connector, controls on, for voltage and ground, key on. If good voltage and ground with no blower action, suspect the blower motor.
Dec 16, 2016 | Chrysler Cars & Trucks
98 century heater blower motor resistor location
look under the passenger side of the dash. There will be a plastic trim panel that will need to be removed. Once its out of the way you will see the blower motor. The resistor will be just to the drivers side of the blower motor.
Nov 15, 2011 | 1998 Buick Century
Do i have to pull the dash back and remove the case to replace blower motor my truck has a/c
no, you remove the blower motor from under the hood.
Disconnect negative battery cable. Disconnect blower motor harness connector in engine compartment, near blower motor. Remove blower motor screws. rotate and tilt blower motor assembly as needed for clearance, remove blower motor. To install, reverse removal procedure.
Jan 28, 2011 | 2001 Jeep Cherokee
Ieplaced the resistor to the blower motor Blower motor still does not work. Do i need to replace the blower motor or switch
If the Blower Motor does not operate on any speed, the blower resistor is most likely NOT the problem. To find out if it is the blower motr or the switch, test for power at the blower motor connector. If there is power the blower motor should be replaced. If there is no power, there could be several reasons for this including the blower control switch, the blower motor circuits or even a problem with your ignition switch.
Jan 22, 2011 | 1998 Dodge Ram 1500 4WD
Hi, i need to remove and replace the blower motor for the a.c./ heater, and dont know where it is located. can you please help?
Blower Motor Removal & Installation To Remove:
  1. Remove the insulator from under the right side of the dash.
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the blower motor retaining screws.
  4. Remove the blower motor.
To Install:
  1. Install the blower motor.
  2. Install the blower motor mounting screws.
  3. Connect the electrical connector to the blower motor.
  4. Install the under dash insulator.
Dec 10, 2010 | 1999 Pontiac Grand Prix
1989 Mercedes-Benz 300-Class
There is a Blower Motor Relay in that system. It is located behind the center of the instrument panel, on connector i27.If it's not the faulty relay, then it is the blower motor .
The blower is controlled by the blower motor in the unit.The blower motor needs to be checked and replaced. The blower motor. The brushes are probably worn and the brushes, or the motor, needs to be replaced. It is located under the front cowl. Check out.Thanks.
Jul 23, 2010 | 1989 Mercedes-Benz 300-Class
Blower motor replacement
Very easy!!!
Here ya go!!!
  1. Remove the right side sound insulator in the passenger compartment.
  3. Disconnect the blower ventilation tube from the module.
  4. Remove the blower motor screws.
  5. Remove the blower motor from the housing.
  6. Install the blower motor into the housing.
To install:
  1. Install the blower motor screws and tighten to 15 inch lbs. (1.5 Nm).
  2. Install the blower ventilation tube to the module.
  3. Connect the blower motor electrical connector.
  4. Install the right side sound insulator.
Jun 03, 2010 | 2004 Buick LeSabre
My heater isnt blowing out any hot or cold air how do i fix problem if i hit blower motor sometimes it will kick on but onlt on high
The blower motor needs to be replaced. Also if it only blows on high the blower motor resister block may need to be replaced as well.
Feb 25, 2010 | 1997 Chevrolet C1500
Need to replace the blower motor on my 2002 silverado
2002 silverado as follows :
1. if equipped , remove the sound insulator panel , remove the blower motor insulating cover screws , disconnect the electrical connector from the blower motor , remover the blower motor insulating cover , pull the retaining tab down while turning the blower motor counter clockwise in order to disengage the blower motor from the HVAC module , remove the blower motor .
2. to install blower motor , reverse the steps .
thanks for voting.
Dec 28, 2008 | 2001 Chevrolet Suburban
Blower motor installation and location
location is right side under dash , procedure is remove right sound insulator , disconnect blower motor connectors , remove blower motor cooling tube , remove the blower motor screws and blower motor , and reverse procedure to install .thanks.
Dec 28, 2008 | 1998 Chevrolet Cavalier
Heating & Cooling Logo
18 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
