Question about Saeco Odea Giro Plus Coffee Maker
How do i find the is the dreg drawer - Saeco Odea Giro Plus Coffee Maker
  • 70 Answers
SOURCE: dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Posted on May 25, 2008
mirran
  • 515 Answers
SOURCE: Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Posted on Jul 11, 2008
PlatoAu
  • 67 Answers
SOURCE: dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
Posted on Apr 10, 2009
EsWorld
  • 1618 Answers
SOURCE: SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Posted on Oct 07, 2009
  • 10 Answers
SOURCE: machine won't work due to dreg drawer
Check to see if your machine has an "exit chute" or similar area where from the used pucks are ejected. The area might be clogged with used coffee grinds and causing a false reading from the machine.
Posted on Dec 15, 2009
My Saeco Royal displays Dreg Drawer full after about 3-4 cups of coffee. i have cleaned the drawer. where do i find the Dreg drawer sensor to clean it.
hi,
this is normal as there is no switch or sensor. In fact the Royal as well as the Magic and others are counting the number of coffees that you have made between two removals of the dreg drawer. For this counter to reset, you have to remove the dreg drawer while the machine is ON, and remove it for about 10s minimum.
Retry and tell me if it is better.
Hope that helps,
M.
Mar 16, 2016 | Saeco Royal Digital Espresso & Coffee...
I have a message that reads Dregdrawer full but it is empty
the machine is counting how many coffee is made,and then it's showing that dreg drawer is full. If you empty it before the machine showing that's full -machine don't know that you are empty it.Now you have to remove dreg drawer for 10 seconds and then put it back!
Oct 03, 2014 | Saeco Coffee Makers & Espresso Machines
Saeco Odea: The brew group is jammed possibly due to incorrect insertion? Cannot insert dregs draw and cannot remove the brew group.
I had the same problem. I got around it by inserting just the grounds container (which sits inside the dregs drawer) and powering the machine on. Then the machine reset itself to the home position. It wouldn't do this with the dregs drawer removed, but putting in just the grounds container fooled it into thinking the dregs drawer was inserted. Hope this helps. JRP
Oct 24, 2010 | Saeco Odea Go
Machine won't work due to dreg drawer
Dec 14, 2009 | Saeco Royal Digital Plus Coffee...
Continually have message saying dreg drawer is missing but dreg drawer is in place
Remove drawer and clean coffee grounds behind it, there might be something keeping it from reaching the microswitch.
Sep 28, 2009 | Saeco Royal Professional Espresso Machine
Dreg drawer cannot be inserted back to its place...
Apr 10, 2009 | Saeco Royal Professional Espresso Machine
Dregdrawer Full
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Nov 19, 2008 | Saeco Royal Digital Plus Coffee...
Dregdrawer full message will not go away
Have you tried removing the drawer with the machine on, leave it out for say 2 minutes and then replacing the dreg drawer again?
There is no dreg sensor. Dreg drawer full works off a counter - depending on when the counter was last reset your drawer may be full but it may be empty.
Simply removing the dreg drawer and replacing it quickly will not reset it. The machine has to think that you have actually taken the time to empty it - a couple of minutes should cover this.
If this does not resolve the issue, you need to get a Technician to take a look.
I hope this helps
Aug 26, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Dreg Drawer
You have to take it to a Saeco service center, i think is a faulty sensor
Apr 04, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Odea Giro Plus Coffee Maker Logo
24 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
