Question about Honeywell HS-1665 Floor Fan
Will not start
Fan will not turn on
Keeps beeping but won't start
I can't take credit for the solution to the fan problem, but I can attest to its merit. It turned out to be my problem too. The fan bearings dry out making it harder to start. This drives more current through it and this burns out the thermistor. If you do the fix here make sure you oil the fan bearings too. http://www.fixya.com/support/t3588983-lg_lhd65ebl_serial_603taac20984
Jul 13, 2014 | Whirlpool Gold AD70USS 70 Pint Per Day...
Why does my brand new wall AC unit turn on but the fan does not work?
Good Afternoon Michael,
I see that you are having trouble with your Frigidaire air conditioner, model# FRA14EHT2, and the fan not turning on, even though the compressor turns on. Being that this is an air conditioning, I suggest either calling your local authorized technician or possibly the manufacturer. One of which will be able to assist and direct you in the right direction of having your air conditioner working. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire FRA14EHT2 14,000 BTU...
Turns on but fan and compresser does not run
start relay on compressor fans will not work if pumps not running
Nov 16, 2013 | Winix WDH751 Dehumidifier
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
Nov 08, 2013 | LG DH30 GoldStar Dehumidifier
Fan Runs On and Off
the problem is dry bushes on the fan shaft. It is best to replace the fan motor unless you have a good appliance electrician who can pull the motor apart ad knows how to lubricate the bushes.
Jun 09, 2013 | Haier HD308 Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Danby Dehumidifier
My Haier dehumidifier is really noisy. If we turn it off and restart it, it will run quietly for maybe 4 minutes and then start getting really noisy again. Any ideas what is causing it and what I can do...
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 14, 2010 | Haier Dehumidifiers
Thanks
I went back and rechecked. If the fan mode is selected, you can only set the fan at one of the three speeds. If you leave it in the fan mode, the dehumidifier will not come on.
Once the fan speed is selected, it will run at that speed in the dehumidifier mode. The fan will keep running, even when the dehumidifier (compressor) shuts down.
The only way to get it to turn off is to use the clock setting, which either selects how long it stands-by before starting , or how long it will run before going back to stand-by. DeLonghi calls it "stand-by," we would call it "off." DeLonghi calls unplugged "off."
I've never turned mine to stand-by, because it will never get my entire house down to 30% humidity (I have it where my air handler returns air to the basement). I live in the greater DC Metro area, where 75% humidity is considered extremely dry.
Apparently the normal mode of operation is fan on unless awaiting a clock start, or encountering a clock shut-down; either condition puts it into the "stand-by" mode.
Sep 02, 2008 | DeLonghi DE500 Dehumidifier
Honeywell HS-1665 Floor Fan Logo
27 people viewed this question
Top Honeywell Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Honeywell Dehumidifier Expert? Answer questions, earn points and help others
