Question about Omron Healthcare 2007 Hem 711DLX Automatic Blood Pressure Monitor with Comfit Cuff
What is considered low blood pressure - Omron Healthcare 2007 Hem 711DLX Automatic Blood Pressure Monitor with Comfit Cuff
Is blood low pressure dangerous?
Only in that is can cause fainting, and if you are driving, or swimming, it could be a problem. It does however make you live longer. you should consult a physician if it has suddenly become low, or if you are feeling fatigued. Read the link at the bottom.
Most doctors consider blood pressure too low only if it causes symptoms. Some experts define low blood pressure as readings lower than 90 mm Hg systolic or 60 mm Hg diastolic. If either number is below that, your pressure is lower than normal. A sudden fall in blood pressure can be dangerous.Mar 10, 2018
Is blood low pressure dangerous Google Search
Apr 17, 2018 | Health & Beauty
Blood pressure at 107 over 58 . Is this normal
its low but it also depends on your age weight and height. and other factors like smoking and drinking. we all have different blood pressures depending on or lifestyles. get yourself checked out at your doctors or pharmacy.
Feb 08, 2018 | Health & Beauty
Blood pressure reading 143S. 85D. When are readings considered dangerous?
Readings of 140s and higher are consider high blood pressure. Same for 90D and above. This article from the Mayo Clinic gives the ranges and advice on what to do:
https://www.mayoclinic.org/diseases-conditions/high-blood-pressure/in-depth/blood-pressure/ART-20050982
Nov 03, 2017 | Health & Beauty
How low is too low for blood pressure?
Generally, if the blood pressure reading is under 90/60, it is abnormally low and is referred to as hypotension.
Most doctors do not consider hypotension a problem unless it is associated with certain signs and symptoms, which may include:
  • Dizziness
  • Fainting
  • Fatigue
  • Problems concentrating
  • Blurry vision
  • Nausea
  • Clammy, pale skin
  • Shortness of breath
Low Blood Pressure When Blood Pressure Is Too Low
Aug 10, 2017 | Health & Beauty
What is considered low blood preasure for a 45 year old female
Always, your own physician is the best source of information. If you are feeling fine, the general guideline is blood pressure not lower than 90/60.
The Basics of Low Blood Pressure
Aug 09, 2017 | Health & Beauty
How low is to low with my blood pressure?
Mayo clinic says: Most doctors consider chronically low blood pressure too low only if it causes noticeable symptoms. (Such as dizziness, especially when first standing up). Some experts define low blood pressure as readings lower than 90 mm Hg systolic or 60 mm Hg diastolic - you need to have only one number in the low range for your blood pressure to be considered lower than normal. I hope this helps!
Mar 30, 2017 | Health & Beauty
What is consider normal blood pressure for a 85 year old woman?
no blood pressure can be considered normal as individuals with different health conditions have different pressures under different conditions
go to your doctor and discuss what he would consider good parameters for your blood pressure to be in for a person of your age and health
Jan 05, 2017 | Health & Beauty
What is a low diastolic reading considered to be for an 88 year old person?
First age is not a factor.
60 mm Hg or less is generally considered low blood pressure
This is usually caused by congestive heart failure, and as far as increasing the pressure it would be a question for your Cardiologist.
Nov 10, 2016 | Health & Beauty
WHAT WOULD BE CONSIDERED LOW BLOOD PRESSURE?IS IT NORMAL FOR MY TOP NUMBER TO CHANGE FROM 104 TO 129 IN ABOUT 5 MINUTES?
There are standard methods for measuring BP. One should be seated on chair, feet on ground, leaned back, relaxed for at least 5 minutes, at least 2 hrs after a meal, .... then repeating this procedure several times daily, and averaging will provide some ave daily BP value.
Using this procedure for hourly BP measures, one can adjust times and doses of BP medicines taken daily.
Nov 12, 2008 | Omron Healthcare 2007 Hem 711DLX Automatic...
Omron Healthcare 2007 Hem 711DLX Automatic Blood Pressure Monitor with Comfit Cuff Logo
54 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
