Question about Toshiba Satellite P25-S507 Notebook
Projecting on a screen
I want to know how to get my toshiba to project onto a screen through a dell projector. The VGA cable is hooked up but is there a button I need to push
    President:
  • 3,278 Answers
You need to select the function (Fn) key with one of the "F" keys on the top row of your keyboard. It may be F4, but look at the keyboard and you'll see a "screen" symbol. So, hold down the Fn key with that key. Press those keys together once or twice until you see the projected image. Good luck.
Posted on Jun 23, 2009
  • NinaE Jul 02, 2009
    Was this helpful ??? Resolve your problem ?? Thanks.
    Sergeant:
  • 220 Answers
Press Fn+F9 or the F key that has this drawning:
Cheers
Hi i have just connected up panasonic home cinema system via my projector and the titles etc are back to front any ideas ?? Regards
Trying to understand your problem. Sounds like an orientation problem with your projector. Check your manual to get image orientation setup correctly for your projector. Look for projecting image onto the front of screen instead of projecting image thru the back of screen. Some times the application calls for projecting from behind screen just like a projection TV.
Feb 14, 2015 | Panasonic 5.1 DVD Home Cinema System 1000W...
It is projecting pink.
Hello, firstly I would try a new VGA cable first and then wiggle the VGA cable in the ports, sometimes the ports become damaged when strain is put on them (more likely to be the laptop VGA port) If this doesn't correct the problem then it is likely to be a polarizing lens in the projector. If so it may be too costly to repair as projectors can be bought for just over £200.
Good luck
Aug 15, 2011 | Vivitek D820MS Projector
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
Projector not projecting anything
Have you try pressing the Fn+F7 key. This will switch between the laptop screen and external screen.
Let me know if this helps.
Mar 28, 2009 | Dell 2200MP Multimedia Projector
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
LP540 Infocus PRojector
first try a new vga cable. if the problem persists, go into the menu and find the settings to that computer output. chances are it's on component. set it to vga. if that doesn't help, reset back to factory default, then set it to vga.
May 01, 2008 | Toshiba TLP 261 Multimedia Projector
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
Toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Aug 26, 2007 | Optoma Projector Multimedia Projector
Toshiba Satellite P25-S507 Notebook Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
