Question about Cell Phones
Can I connect my galaxy s2 to my philips DVD #dvp5992/ f7 true the usb port.
  • 641 Answers
Try this:
Posted on May 15, 2014
4 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Cannot charge Samsung Galaxy S2
first, test th charger with another phone to confirm if its working or not.
If the rempte is working, then it means the charging port of your phone is defective and needs to be replaced.
Regards.
Posted on Jan 05, 2012
Testimonial: "Thanks!"
  • 59 Answers
SOURCE: USER MANUAL FOR A SAMSUNG GALAXY S2
http://www.manualusersguide.com/samsung-galaxy-s2-user-guide-manual-pdf-download.html
Hello here is the link where you can download the user manual for your phone. I have downloaded it for you so you dont have to do it but for some reason i cant attached it in here. So instead i give you the link. It is easy jsut go in this site and at the very bottom you will see download samsung user manual pdf. .just click it and you will be downloading the pdf file in no time..
Hope this can help you..have a nice day..
Posted on Jan 17, 2012
SOURCE: Samsung Galaxy S2 manual
PUK is a safety code of your SIM card. It has nothing to do with your phone. You need to look for the envelope / bag / box that your SIM came with.
Posted on Mar 30, 2014
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Tip
YOU MUST NOT MISS IT!!! -----------http://www.2kuu.com --------- The website...
<span>How to fix the orange screen back to normal!</span><br /><br />The other day i turned on my Philips DVD player model number: DVP5992 and the screen was orange red, instead of blue/grayish! I have tried to google the problem, but no luck. So what i did is, i disconnected the power cord and the HDMI cable and waited for like 30 min. After 30 min i plugged it back in and my screen went back to normal, being blue and gray!<br />If you have this problem, do this, and your screen will turn back to normal.<br /><br />Also if you want multi-regional code to play all regions DVD's, do this:<br /><br /> press Setup <br />select the Preference Tab (4th setting to the right)<br />keep that tab open and Press 1,3,8,9,3,1 <br />Press up/down on remote key to select "0" <br />and hit "OK" then hit setup to exit. <br /><br />good luck and enjoy!<br />Naztech<br />
on Jan 25, 2011 | Philips DVP5992/37 DVD Player
Tip
Philips DVD player Model: DVP5992 Fixing the orange screen
on Jan 03, 2011 | Philips DVP5992/37 DVD Player
Samasung galaxy s11 wont bring up usb up top lefthand corner when plugged in
Does that USB port work with other devices? If it does then you need to make sure you have the driver's installed for the Galaxy S2 which you can get from Samsung's website by downloading Samsung Kies and installing that on your computer. After that if it still is not connecting to your computer then you would need to call Samsung Tech Support to make sure the cable/port are working correctly.
Oct 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
Nov 18, 2009 | Philips 42PFL5603D/F7 LCD TV
How can I change my PHILIPS DVP5992/37's Region Code from ''1'' to ''9'' or ''0''?
HI!
I think you'll find this very useful!
To multi-region your machine:
press Setup
Press 1,3,8,9,3,1
Press up/down key to select "0"
and press menu to exit.
Good luck to you and enjoy!
Jul 25, 2009 | Philips DVP5992/37 DVD Player
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
